Which carbon 29er fork
- Chicken Legs
I have had a couple of carbon 29er forks, the Van Nicholas was damaged by flying slate (thanks Gabes) and a Maxxis which will not be purchased again !
So what is the general consensus on the following; Van Nicholas VNT £215, Whisky No 7 £285 or the Niner carbon rigid nude £350.
It would be very easy to go for the Van Nicholas, (cheapest), as it did take a hefty whack and still remain intact but I couldn't trust it with a dink
in it, so what are your thoughts on the other two ?
Andy
Andy
Re: Which carbon 29er fork
In typical fashion, I'll suggest another alternative - Exotic CC.
Can't speak about the Niner rigid nude as I've got the Niner RDO carbon...but I can say that Niner do a good job in the fork department. Only downer about it is my Revelate bar harness is chewing it up :(
I have to say I've been very happy with my Shand-branded one. Like all other carbon forks out there, its the product of some far-eastern factory, but in terms of style, it's a lot nicer than some out there, and it terms of function, at least as good as the rest. Can be had for circa £250, but you'll need to email them I think.
Dragons by special request (and cost!)
Sorry to hijack the thread, but what a-c length are those forks Ian please?
I'm looking at an exotic one. You can get one with a 15mm maxle for just over £100 and the crown design with alloy steerer means less faff with bungs and routing a cycle2charge cable. The circular leg profile should also mean adding cages is easier.
- JohnClimber
For a little/lot more money and one hell of a lot more comfort look no further than http://www.laufforks.com/lauf-trail-racer/
485mmGari wrote:Sorry to hijack the thread, but what a-c length are those forks Ian please?
Thanks. Way too long:-(
I think the Bahookie is corrected for 120mm forks, so that's a point worth noting for anyone considering one.
I'm on a similar mission, looking for a set of 15mm through axle tapered disc compatible forks with an a-c of around 400-420mmm and clearance for 45-50mm tyres. The only success I've had is with the whiskey number 9 cx fork or if I compromise on tyre width, there are a couple of options from TRP and Easton. All of these are between. £350 and £400 which seems very expensive. Many of the newer breed of gravel bikes and disc cx bikes are being specked with through axle but getting reasonably priced forks seems tricky at the moment. Any thoughts?
- Chicken Legs
Thanks for your input chaps, the Shand looks nice, the Lauff looks odd to me, (sorry John) but I do quite fancy the niner,
decisions, decisions
@pistonbroke, that is exactly what I am after for my WTF. Most of the newer gravel bikes have 400mm a-c forks on them; RLT, OnOne models such as BishBashBosh and the Tomac etc, but not for resale separately Kenesis do a CX fork but not 15mm unfortunately.
- JohnClimber
It sure looks odd, you can't see it while you are riding it but you can really feel it "absorb the ride"Chicken Legs wrote:Thanks for your input chaps, the Shand looks nice, the Lauff looks odd to me, (sorry John) but I do quite fancy the niner,
- Single Speed George
my on one carbon monocock forks are great and only £140, pretty comfy , and dead strong.. taken them over jumps and down drops etc good stuff !!!
Another option?
http://enve.com/products/mountain-fork/
Bit expensive but they look unbelievably good.
I've got a set of the Niners' ......excellent quality, look great, very light yet robust but pricey
I've also got some of the carbon legged aluminium steerer exotics.......cheaper, still light but harsher ride
hope this helps
hope this helps
as above I own both niner and exotics, niner for general use and the exotics for bikepacking duties, niner tracks really well and super strong and light, but the exotics have had a real battering and I like the fork crown as harness fits better and no need to tape it up, would recommend the alloy steerer though
I've had the on one carbons they are strong! Quite stiff though.
Run niners now. They are much more compliant and comfy
My Whiskey forks are good (No 9), They are good. Stiffer than Krampus steel forks, not as stiff the on-one's that Ian and George mention.
Using the Salsa Firestarter fork, which is damn near as the same Whiskey N0.9 Mountain fork, for over two years now. Can't fault it in any way. Comfortable, light, and has taken a hammering offroad.
Have used an exxotic in the past and found it a bit flexy for me under hard cornering, but no worse than an old pair of SIDs
Johnclimber - with regards to the Lauf forks I repeat:
Salsa do a carbon firestarter fork which is 15mm through axle I think. I've not used it because I went for the cheaper steel option. It also has the 3 bolt pattern on the legs to use salsa's anything cages (which I do have).
What GregMay said
What GregMay said
- mountainbaker
I'm with FLV, Whiskey no9 forks are great. Happy with mine, stiff enough, but compliant enough. Nice and burly too. I had on-one forks on the lurcher, I didn't find them that stuff, and man, they were fugly.
Axles came loose in mine. All the time, First one and the one mike replaced it with.
