DIY pot cosy
DIY pot cosy
Any tips/template for a diy pot cosy, remember seeing one made from foil bubble wrap.
Cheers Gary
Cheers Gary
Re: DIY pot cosy
That's what I used. A circle for each end, a piece to wrap around. I made an inner and outer to form a good "lid" and a slot for the handles. Silver duct tape to hold it together.
Re: DIY pot cosy
Cheers exactly what I’m after, many thanks
Re: DIY pot cosy
Detailed instructions can be found here: https://bearbonesbikepacking.blogspot.c ... -cosy.html
Re: DIY pot cosy
Or as another option, if you don’t mind paying is Tredlite gear who make insulated cook pot bags.
I’ve got one. It’s insulated on the bottom and sides and the top is wider so you can pull it down the sides of the pot.
https://www.treadlitegear.co.uk/evernew-14-c.asp
- 99percentchimp
Re: DIY pot cosy
I made one as Colin's post above but stopped using it as I tend to heat in a 'Pour and store' bag and so just made a foil bubble wrap 'envelope' for that - with a slightly wider flat bottom so it stands with the bag inside and enough width for the food to be stirred and reheated - simple rectangular construction and 3 sides taped - easy to carry too. Works well as do the pot cosys.
Conquistador of the pointless
Re: DIY pot cosy
One of the reasons for the way my pot cosy was made so tall was so that I could stand up a P&S bag in it.99percentchimp wrote:I made one as Colin's post above but stopped using it as I tend to heat in a 'Pour and store' bag and so just made a foil bubble wrap 'envelope' for that - with a slightly wider flat bottom so it stands with the bag inside and enough width for the food to be stirred and reheated - simple rectangular construction and 3 sides taped - easy to carry too. Works well as do the pot cosys.
I've since made a P&S cosy too, in much the same shape as a P&S bag, so it folds flat but pops out to stand up when required.
Re: DIY pot cosy
Cheers I’m going to have s go at the one on the blog.
Many Thanks for the replies
Re: DIY pot cosy
what P & S bags do you guys recommend?
Re: DIY pot cosy
THey all seem much of a muchness - Pour and Store, Soup and Save, etc.what P & S bags do you guys recommend?
Re: DIY pot cosy
*Engage tightarse/thrifty Yorkshireman mode*
Get thisen some "tip and zip" from't home bargains. About £1 for ten and just as good as the fancy version.
*Removes flat cap*
*Removes flat cap*
Re: DIY pot cosy
Aldi do them regularly. I can't remember what they call them though. I once asked my Mrs to get me 8 bags. She bought 8 bags of 8 bags....
Re: DIY pot cosy
you cannot blame her for you giving unclear instructions
Cheers so basically they will all work, if i add boiling water to them, without melting.
Re: DIY pot cosy
The pot cosy king explains everything about pot cosies http://www.theoutdoorsstation.co.uk/201 ... ng-system/ he starts cutting and sticking at 4.25
