Hi there,
At a wedding in Buxton over the weekend and would like to bivi if the weather is kind.
Can anyone recommend anywhere suitable that isn't too far from the center?
Ideally would walk out.
Thanks,
N
Bivi Near Buxton
Re: Bivi Near Buxton
snack_ie wrote:Hi there,
Thanks,
N
Combs Edge is nice and fairly close to the centre, just North. Or if you fancy going South have a look at Solomans Temple, loads of woodland on the way up to it then lots of small hollows and ridges, plus the 'temple' which is a victorian folly.
If you're walking you probably won't get far, so I would suggest heading out of Buxton on the A5004 (Long Hill) and turn right at SK 043748. You should find a few spots along there that should make reasonable overnight accommodation.
Cheers Lads,
Will have a look at them!
N
N
Int that the way to combs?Bearbonesnorm wrote:If you're walking you probably won't get far, so I would suggest heading out of Buxton on the A5004 (Long Hill) and turn right at SK 043748. You should find a few spots along there that should make reasonable overnight accommodation.
You can get to Combs that way or it'll drop you out on Elnor Lane.Int that the way to combs?
