Just finished this for someone. They use a Toaks 550ml pot which is roughly the same diameter as the Mitymug but shorter. I couldn't recommend an 8g stove on something that wide unless it was used with a special windshield and the 22g was a little 'too much' ... this is the result, a 12g stove. It's the same height as an 8g but as you can see, it's a few mm wider, it also features different jetting.
12g Stove?
12g Stove?
Re: 12g Stove?
It's a Goldilocks meths stove
Re: 12g Stove?
For porage?
Re: 12g Stove?
Looks great
Re: 12g Stove?
Ive thought the same with the 8 and 22, so added to the never ending stuff list
Re: 12g Stove?
Any chance you could make me a 14g one stu
Re: 12g Stove?
Would you like me to just make you a heavier 12g one?Any chance you could make me a 14g one stu
