Fat Bike Mudguards
Fat Bike Mudguards
I have a MuckyNutz Fat Fender XL up front, and it's fine.
It's the rear that annoys me the most - water gets flicked forward and onto my legs/ into my shoes/ down my gaiters. All the ones I've seen are seat post mounted and don't really stop water being propelled forward.
I have had a 15 mins of googling, to no avail - my google-fu is weak this evening.
Just wondered what people use?
- JohnClimber
Re: Fat Bike Mudguards
Mud Hugger are working on a Fat Bike specific rear mud guard as we speak.
Great, will it be available next week?
Could you use a seatpost one and doctor a down tube one onto the back of the seatpost?
Might have to trim it here and there?
Pretty sure I've seen* the Mucky Nutz front one used as a rear guard by mounting it on the seat stay bridge. Not sure if was the the fat face or XL version.
*either on UK fat bikes or STW.
I have a fat Face standard one on the rear of my seatstays
that's the picture I had in mind thanks Firestarter.
Firestarter - thanks, I have one of those on the front and an prototype one in the same position on the rear (without the bend in it), but it doesn't do the job. Is the angled one more effective?
It works OK Ian I don't know how it would compare to yours. It hugs round the tyre nicely so seems to catch a fair bit
You need to break out the CAD, Ian ;-)
(cardboard aided design)
Not sure cardboard would last very long in the wet
- pushbikemike
I read about this somewhere else: I took a mud hugger mudguard for a 29er and applied some heat from a hairdryer then molded it to fit my fatbike. Works pretty well.
http://singletrackworld.com/forum/topic/fat-mud-guard
Hmm, would that be something like what's on this bike then? : http://fatbiking.eu/?p=6247pushbikemike wrote:I read about this somewhere else: I took a mud hugger mudguard for a 29er and applied some heat from a hairdryer then molded it to fit my fatbike. Works pretty well.
- pushbikemike
I'm going to be fitting a Crud 29er set to mine.
Been thinking about this myself and considering butchering/modifying an SKS Velo 65mm rear mudguard.
The idea is to secure the mudguard using the cross member between the back stays and same on the chain stays.
If you dont have a tapped hole available use pclips looped on the cross piece and secured on the mudguard.
The mudguard is only for the back of the seat tube use a normal rear X Blade type guard for the rest.
You can trim the mudguard to overlap the blade.
Hope that makes sense.
Any idea on the design style?JohnClimber wrote:Mud Hugger are working on a Fat Bike specific rear mud guard as we speak.
ie. Seat post mounted rear?
Try http://stores.bigomfg.com/fender-kits/? ... red&page=2
I wanted for some for a Krampus but shipping doubled the cost.
If you decide to go for one of theirs give me a shout as I might want to tag an order on.
I made something similar to firestarter's pic out of a 6 pint milk bottle, put a couple of holes in and zip tied it to the rear brake bridge It worked well but the plastic is a bit floppy. I've been meaning to make another with some strengthening to stop it bending. i'll post a pic when i get round to it.
