New for Loop bar users.
New for Jones Loop bar users ... it's called a Gnarwhal, apparently. Designed for a nice aero tuck or spearing other riders, so a multi-use item :-bd
Re: New for Loop bar users.
Bearbonesnorm wrote:New for Jones Loop bar users ... it's called a Gnarwhal, apparently. Designed for a nice aero tuck or spearing other riders, so a multi-use item :-bd
How weird is that?
I was just out for my first training ride preparing for the World Championship Beach Race over in Holland that I've been invited to attend (on my fat bike against pro racers on Monster Cross Beach Racers :shock: ) and when down in the aero position today I though, a bar end fitted just on the front of the loop would be great.
I should have ridden to the copyright office on the loop :oops:
A what?
Ben98
Post by Ben98 »
I was planning on making a single aero bar extending from my stem as well, clearly it wasn't a unique idea. :roll:
A what?
Presumably a fatbike with drop bars....
Ever tried riding a slack seat-angle bike in an aero tuck? : ) Great for most bikes though.
And this .. Image
is one of the greatest things I have ever seen on wheels. Love it.
That Jones bike doesn't have enough cables... :-bd
Dyffers
Post by Dyffers »
If he's making a bar end with a double bolt opening (which it must be to go on a loop bar) then great; nobody else does. However, I suspect a bar end with a Jones logo will be priced significantly above my 'oooh lets give that a try' level. :roll:
benp1 wrote:That Jones bike doesn't have enough cables... :-bd
That's the forks?
:grin:
A what?
The Dutch riders seem able to race along a beach on normalish cx bikes...... :mrgreen:
http://www.koga.com/en/bikes/race/colle ... tm?frame=H
A what?
That's the monsters I was on about, half the weight of my Fat Bike ridden by riders half my age and half my weight :roll:
Dyffers wrote:If he's making a bar end with a double bolt opening (which it must be to go on a loop bar) then great; nobody else does. However, I suspect a bar end with a Jones logo will be priced significantly above my 'oooh lets give that a try' level. :roll:
Spotted this problem when I dug out my old bar ends :roll:
Yorlin
Post by Yorlin »
A what?
They look very interesting!
Hmm you can get the bars for only £40... http://www.cyclesense.co.uk/m61b0s90p15 ... Racer-2015
Nice colour anyway!
That's the forks?
:grin:
I meant the cables, just looks like there's loads going on
I guess brakes front and rear
Gears cranks and rear
Dropper
Mpolo
Post by Mpolo »
presumably named after this guy not sure what the G is about though
mountainbaker
Post by mountainbaker »
I much prefer my friend Scott's setup by Rob English: http://www.englishcycles.com/custombike ... vide-ride/
I will do the same next time I do TD.
Mpolo wrote:
The G is for gnar, which is some kind of expression used to imply tough/aggressive. I think :???: :roll:
After thinking up the idea before I saw this post :oops: :roll:
I found that the metal on the bar ends was malleable enough to stretch over the wrapped bars and I closed them up with longer bolts.
Test ride tomorrow
I have to say John .... rather you than me.
You may find the aluminium won't take kindly to that much manipulation.
Cracking idea. :-bd
Bearbonesnorm wrote: You may find the aluminium won't take kindly to that much manipulation.
They are not load bearing just for resting on, so should be ok :FingerCrossedIcon:
ZeroDarkBivi
Post by ZeroDarkBivi »
Love that setup on the Rob English bike - he really knows what he is doing.
I quite often rest my forarms on the bars to give my hands a rest and after about 10 mins my neck starts killing me. Fine for a 40k TT but not for anything else
I have some old profile aero mini clip-ons that have a 2pc split clamp, they have been offered up to the front of my loop bars but never used. I did find I could get into an aero position just by resting on the bar with a sort of arms-crossed position, works ok on road. Just not a nice position to pedal in for me, if the seated position is as comfy as it can be then the aero thing doesn't feel good. Depends on the bike I expect. That English bike looks like it has a good solution with the arm rests further back, can see that being comfier.
Pat
Post by Pat »
I had this set up on my j bars for a while....it was good, but looked knobby! I then just fitted some tiny power studs to the hooks, which are really good and look ok too....
Mandicky
Post by Mandicky »
JohnClimber wrote:After thinking up the idea before I saw this post :oops: :roll:
Test ride tomorrow
John, I'd check the rules for your race as I know a lot of competitions don't allow anything pointy (eg tri-bars) sticking out the front of the bike.
It does make for a good riding position though :smile:
Rich
