Singular Rooster 29+ (frame and parts)
Size medium (including anything cage compatible rigid forks), yellow plus 29+ rear wheel (Northpaw rim on black Hope), black Hope front hub (needs rim, spokes and building) and (probably) new Acros headset.
Frame, forks, rear wheel and hub are all BNIB.
£850 or offers.
Re: Singular Rooster 29+ (frame and parts)
That didn't take long.
Mleh, just not fussed at the mo :|
I put the box in the garage and counted bikes plus frames and there were 13 :o Riding has dropped off in last year so the number just seems silly.
In a few months, if it doesn't sell who knows :cool:
Bump.
Open to offers.
Front hub is red BTW, not black.
Headset now definitely exists and still BNIB.
stretch it to make it a XL :cool:
How tall are you Monkey and what shape.. (as in tall or short upper body etc.)?
Apart from the front wheel, I probably have enough to put it together (apart from the space....but then that hasn't stopped me yet :lol: )
I'm 5'10" with a big (ish) ape index (i.e. wide arm span) and 32" inside leg. Tend to ride medium / 17.5" / 18" frames.
I ride a medium Gryphon and Swift (though find the latter a tiny bit too short with an inline dropper and 70mm stem, though not so bad I feel the need to lose the dropper) so a medium Rooster seemed the "right" size choice for me. As I've never built it up I can't really say what the fit is like. Several folks on STW and here might be better for advice as they have built theirs.
wildgecko
Post by wildgecko »
I'm 6'0" with a 33" inside leg and ride a large Gryphon and Rooster. Have got a 3/4" set back seat post and a 90mm stem with OG bars on the Rooster. Possibly a little short in the TT at the mo but as I'm running it SS I spend a lot of time out the saddle so it's not bothering me enough to do anything about it!
Hope that helps
Si
