For Sale
Six moon Designs 49" Pole for the Lunar Solo
Easton Custom Carbon 6.3 Pole 1245mm long, Diameter 8.8mm , folds into three, packs to 445mm long,
Black, shock corded, tip one end, dome the other, Ultralight @ 52g,
A bit flexi in use but ideal for the summer
Bought from Ultralight outdoor gear for £39.99
Mine has been used once, £25 posted
Pole-A-Bear Carbon Pole
Spiral wrapped carbon Pole, 1245mm long, Diameter 12.8mm, folds into three, packs to 452mm long
Black, shockcorded, tip one end, dome the other, weight 113g
Bought for £60, mint condition used half a dozen times,
Very strong and stiff, Easily altered to a shorter length
£35 posted
SOLD : Carbon poles
SOLD : Carbon poles
Re: F.S Carbon poles
Hi Stuart, yep it was spot on i used it at the weekend, cheers Mark
Interested in the pole a bear 1245cm pole, but am miles away from my Trailstar to check whether it's right for it.
(Unless Stu or anyone else can confirm if such a length is good for a cuben Trailstar?)
Nearly all the TS poles I've made have been 120cm - 125cm so it should be fine.
This particular pole is made from 'roll wrapped' carbon so it has a thicker wall than woven, which makes it reet strong.
Hi Ian
I googled it and they recommend 1200mm for the centre pole
so a little trim with the hacksaw and you are in business
Cheers Mark
Cheers Mark
Great, I'll take it then. Can you PM your payment details and I'll try and get it sorted in next few days. Going to be mobile until Sunday, so I'll do what I can with the mobile signal...
Pole a Bear sold to Ian
Ian... pm sent
Ian... pm sent
