The Clearout Continues (incl.. some free)
Had a re-sort of the spares bin. Some is a carry over from the previous advert (with revised prices) but there are some additions too:
WHEELS
Chris King/ Exposure PD8/ Carbon Wheelset
- King ISO disc hub, 9/10/11sp compatible, in black anodised laced to carbon rim. Rim is 29mm external width, 21mm internal, 29mm section depth.
- Exposure PD8 Dynamo hub, in black laced to same rim as above.
- Bought for a project, but change of spec means they are now surplus.
- Rear weight is 995g
- Front weight is 1104g
- Priced to sell at only £350 SOLD
Hope SS Rear Wheel
- black, includes sprocket spacers and Token lock ring. Bearings good. Stan's 355 29er rim a little tired looking, but perfectly true and round.
- £60 SOLD
CRANKS
Middleburn RS8 Cranks
- arms only, silver, 175mm length, square taper.
- £50 SOLD
Middleburn 5-arm spider
- to fit above cranks - £15 SOLD
Image Image
Middleburn Uno Rings
- 36t, 3/32nds, not very worn at all - £20
- 32t 1/8th, a bit more worn that the 36t one, but still perfectly usable - £15 SOLD
Surly Stainless ring
- 33t, 5 bolt (will fit ave spider), not very worn at all - £15
Race Face Bash Guard
- 4 bolt, 32/34t, black - £15 WITHDRAWN
Hope thick/thin ring
- 4 bolt, 32t, not very worn at all - £15 WITHDRAWN
HANDLEBARS
Salsa Woodchipper 2 bars
- 44cm (centre to centre), minor cosmetic scuffs but otherwise, very good.
- £40 SOLD
Jones Bend H-Bar
- like the Loop bar, but without the loop bit
- 660mm width, black
- Some minor cable rub has lead to a very slight indentation at one point, but nothing that causes me any concern. Not seen when fitted
- £50 SOLD
FORKS
Manitou Tower Pro 29er forks
- 80mm travel, white, 15mm thru' axle, 1 & 1/8" straight steerer, recent service, very few marks. A nice fork. Moving to tapered head tube forces sale...
- £150
Image Image Image
STEMS & SEATPOSTS
Hope Stems
- 90mm by 6 degrees, in black
- One older model with some scuffing and rub from a bar harness - £20 SOLD
- One newer model with very few marks on it - £30 SOLD
Thomson Stem
- 100mm by 10 degrees, in black
- very good cosmetic condition - £30 SOLD
Image Image
Hope Eternity Seatpost
- 350mm by 27.2mm.
- Approx 240mm of clean post before insertion marks
- £25
Thomson Elite Seatpost
- 400mm by 27.2mm
- Approx 260mm of clean post before insertion marks
- Some cosmetic rubbing from a seat pack
- £25 SOLD
Image Image Image
DRIVECHAIN
Surly Singleator
- black, near new condition, but only with one spring (push down)
- £20
Shimano Bar End Shifters
- 8sp, silver. Full working order
- £25
Shimano XTR 8sp Cassetter
- 12-32 8sp Ti cassette. Lots of life left in it yet.
- £25
Shimano XT Rear Mech
- Long cage, shadow version, conventional pull (7/8/9sp)
- Sound all round, with not much use.
- £20 SOLD
SRAM 9sp XO Shifters
- pair, full working order and good condition all round.
- £65
SRAM XO Rear Mechs
- choice of two, both full working order, both mid-cage length and with no alignment problems
- with alloy cage £35
- with carbon cage £40
Cane Creek SCR-5 Brake Levers
- Hoods not very worn, few scuffs on the levers, but otherwise good condition.
- £15
SKEWERS & CLAMPS
Hope QR's
- Both older and newer styles
- Silver Ti: £12 WITHDRAWN
- Black steel: £12 SOLD
Hope Seat Clamps
- Black QR, 31.8mm WITHDRAWN
- Black bolted, 31.8mm
- £10 and £8 respectively.
FREE STUFF
The following are all free to a good home, you just need to cover postage or come and pick it up.
If you claim something free, it'd be good to pass on the love and offer something for free too.
Crank Bros Acid pedals, complete with new replacement bush kit. No cleats. GONE
Atom Lab Flat Pedals GONE
Answer Flat bar - 9 degree sweep, I think. 685mm width WITHDRAWN
Carradice saddle bag - a spot prize from WRT 2010, I think. Never used and not required... GONE
Think that's it. If you're reading this, thanks for making it to the bottom of the post :-bd
Prices are (hopefully) pitched on the keen side, but don't include postage.
As before, I'll donate 2% of net sale proceeds to The Bear! :smile:
Thanks,
welshwhit
Re: The Clearout Continues (incl.. some free)
Post by welshwhit »
Hi Ian
msg sent re the Thomsom Stem
Drew
Ben98
Post by Ben98 »
Hi there Ian, what are the weights of the hope qr's please? And are they 135mm rear?
Ben
Ben,
Silver = 103
Black = 120
Turns out the black are steel axles, not Ti, so they'll be the same price for either pair, depending whether old or new style (or colour) is more important to you than weight (all 17g of it ;) )
Both 100/135mm too.
Stem sold to Drew - cheers :)
wildgecko
Post by wildgecko »
Ian,
Interested in the carbon / Dynamo wheels please. Will they take a 2.4 tyre running tubeless ok or are they a bit narrow?
Si
Si,
They come up wider than a pair of Crests, so would expect they'll take a 2.4 tyre no problem.
Cheers,
Ben98
Post by Ben98 »
Cheers for that Ian, unfortunately no weight loss to he had so I'm going to have to turn them down :(
Gilbo71
Post by Gilbo71 »
Hi Ian,
I'll take the Jones bars and the Atom Lab pedals if they are still available?
Are the carbon 29 or 26 flavour?
Yep, bar and pedals still available. I'll send you a PM.
Carbon Wheels are 29", yes.
Artie Fufkin
Post by Artie Fufkin »
Yes Ian,
What kind of axle fitting is the CK single speed hub.
I've got a 10mm QR, will it fit?
Also, are the carbon rimmed wheels sold yet?
Adam.
ianfitz
Post by ianfitz »
I'll take the single speed wheel please. PayPal to your gmail address?
Are you coming up for the Yorkshire 300? Or going to the teddy Bearbones? There's no rush for it
HUX
Post by HUX »
I'll take the XT rear mech please Ian if its still available. Cheers
Artie Fufkin wrote:Yes Ian,
Adam.
The CK hub was geared not SS, and now sold in any case!
ianfitz wrote:I'll take the single speed wheel please. PayPal to your gmail address?
Certainly. Teddy Bear Bones most certainly - not all that far away either really.
HUX wrote:I'll take the XT rear mech please Ian if its still available. Cheers
Sure thing - I'll PM you.
Updates:
Bars and pedals sold to Gilbo
Wheels sold to wild gecko
Thanks chaps :grin: :-bd
optimistic mid week bump just in case there's any interest in what's left :smile:
stevenmcco
Post by stevenmcco »
Do you still have the Thomson seat post for sale?
thanks
steve
Ben98
Post by Ben98 »
Any chance the crank Bros pedals are still up for grabs?
Ben
Ben, yes still got pedals. Would need to work out postage costs on them
Steve, I have the post too if still interested.
Ben98
Post by Ben98 »
Ian wrote:Ben, yes still got pedals. Would need to work out postage costs on them
Sounds good if you could work out the postage please? Assuming it's not a ridiculous amount then I'll take them please! :-bd
Postage coming out at £4.00 second class small packet. If that's cool, fire a PayPal payment over to ianbarrington at gmail dot com and PM me your address and I'll get it in the post in the morn :)
Cheers.
I've updated the original post to show what is/isn't available. A few bits are withdrawn for the bike build for my son
Ben98
Post by Ben98 »
Have sent the money Ian, my address was attached to the money, if that's no good I'll pm you it?
Got it, cheers Ben. In the post tomorrow for you.
Just updated the original post with current availability. Still a few things left. Open to reasonable offers. Cheers.
Ben98
Post by Ben98 »
Pedals arrived a fair while ago, many thanks Ian! Cheers!
Gari
Post by Gari »
Hi Ian, will the rear mechs work with a 10spd shifter do you know?
Gari - no, I don't think they will. This article http://blog.artscyclery.com/science-beh ... atibility/ appears to suggest the pull ratios are different, and measuring a 9sp and 10sp Sram mech I have here, the lever arm on the 9sp is longer than the 10sp one.
