101 uses of a sock
101 uses of a sock
I've always appreciated the benefit of gear used for bivi-ing that can be put to multiple uses, saving weight and bulk etc. Whilst replying to a thread it struck me the humble sock is one of my best bits of multi-use gear I have.
Can you think of anymore than these and/or what's your multi-use bit/s of kit?
Socks:
Riding in.
Sleeping in.
Phone cover.
Glove substitute.
Coarse grade water filter.
Storage bag.
Padding when packing.
Absorbent pad.
Tea towel.
Socks:
Riding in.
Sleeping in.
Phone cover.
Glove substitute.
Storage bag.
Absorbent pad.
Tea towel.
Re: 101 uses of a sock
Mug/pot cosy
Fly swatter
Semaphore flags (if red)
Bottle cover/jacket if in freezing conditions
Fly swatter
101 uses for a CLEAN sock!
Cosh for the wilder territories.
Penknife +sock = emergency bog roll (100% wool =biodegradable )
Seems like a waste to cut it up ... couldn't you just give a rinse when you've finished?Penknife +sock = emergency bog roll (100% wool =biodegradable )
There was an alternative use for a sock in the original "American Pie" film
I've drunk beer through a used one before. Life's shortJoshvegas wrote:101 uses for a CLEAN sock!
- Dave Barter
Weapon (see the film Scum for more details)
A glove puppet.
You can then idle the hours away chatting to it when your miles from civilisation and haven't spoken to anyone in days.
A bit like the football in the Tom Hanks movie Castaway.
Blog - thecyclerider.com
Wind sock, willy warmer, fish trap, carrier bag, pork chop sideburns (you need a pair obviously otherwise you would look silly).
Cut the toe seam to make them tubular and you have arm warmers in a pinch.
Chain rag, I wouldn't use it for much after that though.
Richpips wrote:A glove puppet.
- JohnClimber
Packing out your lycra if you don't wear baggies
Don't use one as a condom.
^thats a good point.
BUT
used with a condom inside.... Make shift water carrier. Proper SAS tip that.
BUT
- MidgeMagnet
Fill 'em with rice, make a good microwavable heat pad if you've got a bad back.
Or you could make a sock monkey/monster.
Nope ... that's what crisp packets are for.Don't use one as a condom.
- adjustablewench
further top tip - leave the microwave at home when you go bikepacking - I'm no doctor but it's probably the cause of your bad backMidgeMagnet wrote:Fill 'em with rice, make a good microwavable heat pad if you've got a bad back
