I have a broken road using 29 + tyres and a mudhugger and a sks equivalent wont clear the tyre
Is there an adjustable angle type mudguard that would work.with a 29+ tyre ? Ie adjusting angle on seat stays ?(my googling says no)
I can probably fit a seat post one but dont think a y of these are wide enough given tyre size.
Given a few on here use + tyres any advice ?
Rear mtb mudguard advice sought
Re: Rear mtb mudguard advice sought
No idea if they're any good, but these polisport ones have adjustable stay angle mounting
https://www.tradeinn.com/bikeinn/en/pol ... 40309462/p
Prior to discovering mudhuggers I used a crude guard on the krampus. Was just abt wide enough to cover 29+ and I could clamp it to the seat tube under the seat post clamp
Thry have them in Merlin ( my lbs) i will nip in and see if it will fit . Thanksthese polisport ones have adjustable stay
I have a seat tube one but its not wide enough amd they get knocked about IME of use. Mudhuggers are so good but just wont work for meand I could clamp it to the seat tube
I've got a Topeak seat post one I've had for a couple of years now which has given good service. Was specific for 650B and was fine for my 2.8" rear tyre. Model XC1-1 1-650 but can't see that they still do that one sadly
Bought from merlin and some minor fettling led to it fitting ..has an extendable bit sonwas able to mount it seat stay bar between them sonproper secure ...not great clearance in claggt mud mindthese polisport ones have adjustable stay
I've got a Broken Road and I use a Mudhugger on the rear with a 29" x 2.6".
I got the longest one and then trimmed a bit off the end.
Not enough room under the fork crown on the front with 29" x 2.6" for a Mudhugger, so use an old Crud guard strapped to the down tube.
