Clearout....
Clearout....
New Hup mountain bike riser handle bars. Clamp size is 31.8mm and are 770mm width. £10
New Ritchey Pro Stem, 31.8mm dia, 100mm long. £5 - SOLD!
Lightly used Controltech mountain bike flat handle bars. Clamp size is 31.8mm and are 765mm wide. £10
New Hup 31.8mm dia stem, 55mm long. £10 - SOLD!
Lightly used pair of 160mm Shimano XT/Saint RT86 6-bolt Ice Tech disc rotors. £15 - SOLD!
New Magura Storm Disc Brake 6-bolt rotors, 1 @ 160mm and one at 180mm. £10 - SOLD!
New Superstar Components Enduro Wheelset, proper bombproof wheels. DHX V6 Wheelset – UK Made Hubs. Wheels DHX V6 Wheelset x 1. DHX 29″ – Black Hub – Black Rim. V-Hub Front Hub Adaptor Build x 1. 15mm BOOST 110mm. V-Hub Rear Adaptors Builder x 1. 148*12mm Adaptor (BOOST Hub). V6 Freehub Body x 1. Shimano 11 Speed. £80
New Shimano Pro inline seatpost, 27.2mm dia, 400mm long. £10 - SOLD!
New Shimano HB-MT 400 Centre Lock front hub. 32h, 15mm through axle, 110mm wide. £10
New Shimano Deore HB-M6000 Centre Lock front hub. 32h, QR, 100 wide. Complete with matching qr skewer. £10
New Superstar Components V6, UK made, 32h, 142mm width, 12mm through axle rear hub. £60
New Shimano 18T DXR singlespeed cassette sprocket. £5
New black Brand X Road Racing Classic Bars. Suitable for road/gravel/cx handlebar. 42cm width, 31.8mm dia clamp area. £5
New GRX BR-RX400 rear disc brake caliper, complete with new pads. £20 - SOLD!
New GRX RD-810 rear derailer jockey/pull set wheels. £10 - SOLD!
Used Hope Pro 2 front and rear 32h hubs complete with quick release skewers. Front is 100mm width and the rear is 135mm, would make a fantasticly tough set of wheels. Bearings running smooth with an upgraded steel freehub. £50 pair - SOLD!
Used Hope 31.8mm stem, 25 degree angle and 70mm length. £5 - SOLD!
Used Deda Zero 31.8mm dia stem, 83 degree angle and 100mm long. £5
Used Wake 31.8mm dia stem, 7 degree angle and 80mm long. £5
Used Exotic Carbon Fibre mountain bike fork. 415mm from centre of axle to the crown race. Suitable for 26″ wheel and 80mm suspension fork. 1 1/8″ steerer cut to 185mm. 100mm qr axle. Lightweight and would also work on a commuter and gravel type bike. Comes with compression type star fangled nut installed. £20 - SOLD!
Used Rockshox 150mm travel Pike Select DebonAir suspension fork. 29″ wheel, 42mm offset, 15mm 110mm axle. Steerer cut to 205mm comes with star fangled nut installed. Stanchions unmarked but could do with a service. £100 - SOLD!
New Shimano BB-UN300 square taper bottom bracket. 68 TA, 113mm axle width. £5
New Rockshox Reverb Stealth Dropper Seatpost for sale. It was a warranty replacement that I never fitted, so is in original packaging. Seatpost dia: 31.6mm Drop: 175mm. £100 - SOLD!
If you can collect from Linlithgow then grear but can post at an extra cost, message me if you have any questions.
Re: Clearout....
I'll take them 2 Shimano rt86 rotors please. PM incoming. Will need posting if that's OK.
Re: Clearout....
Check your mailbox it may be full
Pm sent re grx caliper and jockey wheels, Pikes and discs (but sort Shaf out)
Re: Clearout....
Could I have the hope stem (posted) please?
Re: Clearout....
Hi, sorry I'd also listed these items on Singletrack but have been a bit overwhelmed with the responses over there and took my eye off this posting. Unfortunately I've already sold the Hope stem, carbon fork, xt rotors, shimano seatpost, Deda stem, grx jockey wheels, grx caliper and Magura rotors. I might also have sold my Pike forks. Ian
Re: Clearout....
No probs. Thanks for the update Ian. V good prices btw, appreciated.Didn't hurt wrote: ↑Fri Oct 11, 2024 3:40 pm Hi, sorry I'd also listed these items on Singletrack but have been a bit overwhelmed with the responses over there and took my eye off this posting. Unfortunately I've already sold the Hope stem, carbon fork, xt rotors, shimano seatpost, Deda stem, grx jockey wheels, grx caliper and Magura rotors. I might also have sold my Pike forks. Ian
Re: Clearout....
Just sold my dropper post too.
Re: Clearout....
Do you still have the superstar enduro wheel set? Any chance of some pics please?
Re: Clearout....
Hi Keith, I've sent you a private message, not sure how to post pics on here but will send some over to you. Ian
Re: Clearout....
Hi Keith, did you get my email ok?
