WANTED : Black 32 Hole Shimano QR 135mm Rear Hub 6 Bolt Disc
javatime
Post by javatime »
Maybe a longshot - any in the parts bins ?? - Ideally Deore/XT type quality
Danofthewoods
Re: WANTED : Black 32 Hole Shimano QR 135mm Rear Hub 6 Bolt Disc
Post by Danofthewoods »
Might well have a few options depending on how good you need it to be and what it's for but will need to have a rummage in the workshop later. They'll be used ones I've kept for parts so may need a bit of fettling before using. IIRC might have one built into a 26" wheel that's good to go if any use.
If just a hub can post down or meet you locally. No cash required, be happy to return the favour you did for me re the Offa's ride.
Will be in touch later......
javatime
Post by javatime »
Many thanks Dan, Part Nos would be useful when you have had a rummage
Danofthewoods
Just had a look while putting tools away after work and got a few options for you...
Deore XT FH-M756. Well used but bearings feel pretty good. Would need going through properly though before building into a wheel. Think SJS do all the spares if anything is needed.
Also got a couple FH-M475s one bit tatty but probably serviceable after a grease up and another built into a 26 wheel (Alex dm20 rim with stainless spokes) that looks hardly used - No marks freehub etc. Don't mind stripping it down if just want the hub.
You're welcome to any of them if useful to you but I think I know which you'd prefer. Make a note on here of preference, if they're what you want, and drop me an email make arrangements.
If anyone else is reading this and has a need for a free/cheap hub let me know but Javatime has first dibs. Equally if you're able to make him a better offer please do so now....
D
I have a brand new Novatec D772 QR 32 hole 6 bolt rear hub with Shimano freehub. I also have a used one (with damaged freehub seal). I think I bought the new hub as a source for the freehub, but then a new frame required a bolt through hub.
With the hubs I can give (offload) 2 or 3 spare (used) freehubs - I found the freehub is very serviceable but the pawls get a bit grubby.
It's been in the pile of stuff to sell for a while so make me a cheeky offer. I can bring to the BB200 in October if that helps
javatime
Post by javatime »
Thanks Steve, but will be going with Dan's XT.
Dan - will pm you
