Unused Cane Creek Headset ZS44 EC44/40 - Tapered.
Missing bottom cup for some reason but does have 2 x double star nut.
Cup is available as a separate part if you search the internet.
All the bearings and dust covers are there.
£20 posted
Cane Creek Headset - incomplete
- P1370554 (1024x576).jpg (57.49 KiB) Viewed 1150 times
Re: Cane Creek Headset - incomplete
Is top cup hidden under the cap ? Also may I ask is that the crown race with the blue border ? Thanks.
No top bit goes in head tube as per normal and cap sits on top.
Parts shown green are the bearing top and bottom.
Bottom bearing is for a tapered fork.
The green bit is the crown race(?).
See https://canecreek.com/wp-content/upload ... ctions.pdf
I’d offer £10 posted if it’s any good? Its use to me is only as spares stock
Apologies Mariner .. I am still unclear from the photo and your description . In the photo I can see the bearing cover and bearing ( but no ZS top cup/race ..) then there is the lower bearing and the crown race ( I presume ) with the blue border + 2 star nuts and bolt/steerer cap . I need to clarify please .
Kaiser
It took me a while but I see what you mean.
It appears both cups are missing.
Looking at the CC diagram I have the bolt and cap, top cover and bearing, bottom bearing and crown race.
So it is even more incomplete than I thought.
OK thanks I'll raise the bid to £13 posted ..if you can be bothered !
