swap shop anyone ? brake levers NOT HYDRO
i want a pair of flat bar disc levers. avids preferably.
i have some Tektro rl340 drop bar levers............ if anyone use such old stuff.
anyone ?
shutuplegs
Re: swap shop anyone ? brake levers
Post by shutuplegs »
I’ve still got the ones on here if of interest ton?
https://bearbonesbikepacking.co.uk/phpB ... 14#p288514
thanks for the offer, but i should have said, i need cable levers, not hydro.
shutuplegs
Re: swap shop anyone ? brake levers NOT HYDRO
Ah. I see, no worries. Hope you find some.
You didn't ask for advice but … if you're swapping drop for flat levers on the same callipers check the pull is the correct length. I switched out my OH's gravel bike's bars and used these (https://www.sjscycles.co.uk/brake-lever ... ers-black/) to ensure they still worked with the Spyre road callipers. Off the top of my head I don't recall whether the pull was too much or too little but know it was somehow wrong.
