Lamp
Lamp
Using a newish but useless wheel (well, the hub section) that has sat in my garage for a couple of years, I decided I would make a lamp. Bought a lamp lead with fittings for £7 and a fancy bulb for £4.50 and after a bit of sawing and chopping, this was the result
- IMG_7521.jpeg (119.68 KiB) Viewed 9770 times
- thenorthwind
Re: Lamp
Brilliant!
Might steal that idea
Re: Lamp
I copied this from an instagram post I saw a while back
Someone else said that, had to double check but yeah, it’s retracted. Not that it worked in the first place…
Re: Lamp
Much much better than your painting efforts
Like that a lot
Like that a lot
Re: Lamp
Might put the pictures in a modern art gallery, they’ll go down a storm!
