Middleburn RX8 X-type crankset in black
175mm
68/73 width with adjustment ring which may allow fitment to boost BBs. Longer spindles can be bought for other setups.
1 x middleburn 4 arm spider Red (but sprayed by me….badly)
1 x 32 mono 4 bolt thick thin chainring. Lots of life
1 x absolute black 32t oval chainring with very little use.
Clearly these are in used but not abused condition. Apologies for being a bit of a ‘rubber’ so as you’ll note the black anodised crank arms are well ‘patinated’ with use.
£75 plus postage anyone?
Middleburn RX8 X-type cranks and chainrings
- E495453B-8D0B-4B1F-AD1F-1B2EACFE7262.jpeg (214.03 KiB) Viewed 461 times
Re: Middleburn RX8 X-type cranks and chainrings
What diameter axle are these please. Will be interested if a new bb is not recto fit to the stooge.
These cranks actually ran on my Stooge before I changed them for XTR cranks.
The axle is 24mm.
The axle is 24mm.
- AFCAE921-E301-41E7-9B65-70B01BC7D906.jpeg (171.8 KiB) Viewed 403 times
Sold pending payment
