FS: Lauf TR Boost fork - brand new
PJG
Post by PJG »
Lauf TR Boost fork.
Regular (for riders over 65kg).
Naked Matte finish.
https://www.laufcycling.com/product/lauf-tr-boost
This is a brand new, unused, uncut, warranty replacement fork, still in its box fresh from Taiwan last week.
RRP. £890
I'm looking for £675 posted.
Edit
Would take 625 posted if that helps anyone wavering.
Edit
575 final offer before it goes on Fleabay :-)
Mike
Re: FS: Lauf TR Boost fork - brand new
Post by Mike »
Would this work with a non boost hub with boost spacers? Interested
yes - I have a boost Lauf and have used a non boost wheel [ converted] into mine without issue
Its just a cheapo Ebay kit that added 5mm to each side and 5mm [ i think] for the brake disc - you need a six bolt for the brake convertor
i strongly advise taping the spacers on or the wheel is hard to remove and install and you can lose them when the maxle comes out
Escape Goat
Post by Escape Goat »
Mike wrote: Fri Sep 09, 2022 12:09 pm Would this work with a non boost hub with boost spacers? Interested
Mrp better boost Adaptors are what I use. They’re pretty good.
In Reverse
Post by In Reverse »
What's the hub Mike?
PJG
Post by PJG »
Price reduced if that helps 👍
velocipede65
Post by velocipede65 »
will it come complete with Warranty or is that in your name only? (esp as they know they supplied it direct to you?)
PJG
Post by PJG »
Hi, there are 2 years left to run on my 7 year warranty. However, that's not transferrable to any subsequent owner.
https://www.laufcycling.com/warranty
But if a manufacturing defect was discovered soon after installation, then I'm sure we could come to an arrangement.
Mike
Post by Mike »
Andy iv a pro 4 hub.. I spoke to hope and he said I could get the spacers butnid have to dish the wheel 5mm but I don't wanna do that as it then wouldn't be transferable to the other fork 😐
Yes Hope Boost in a weird way by just making one of the 15 mm spacer bigger hence the wheel needs to be dished - its a terrible solution and better ones exist
You can just use your standard hub and get a boost kit that adds a 5 mm spacer either side and 5 mm to the disc and this will work - the hope way does not require you to add a spacer to the disc brake but its a daft idea - No one wants to dish a wheel for boosting
It does work Its what i do on my Lauf
eg
https://www.ebay.co.uk/itm/363704363000 ... BMjOnj_-tg
PJG
Post by PJG »
Bumping this with a further price drop.
Teaman
Post by Teaman »
Any idea on why this fork has been discontinued as per the website?
