Ben Alder Circuit (picture heavy)
So our second ride of the trip involved a circuit of Ben Alder. If you haven't read it then fatbikephil's blog post about the trails in the Ben Alder area http://philsbikepacking.blogspot.com/20 ... rides.html is well worth a read. Our original intention was to get the train from Bridge of Orchy one stop up to Rannoch and ride the loop from there but there were no bookable bike spaces on any train so we had a rejig and started from Laggan instead.
What would now be the start and end of the route is part of the original HT550 route until Alan switched the start to use the singletrack over Bealach Dubh past Ben Alder. This was done as much to move 60+ riders from having to weave in and out of the WHWers all the way to Kinlochleven but it's probably better riding (apart from one bit which we'll come to).
The initial climb is nice and steady.
This gets you to Loch an' Earba. All this is part of the area used for filming the TV series "Monarch of the Glen" so it's quite likely you'd recognise some views.
Easy riding along the loch side.
Rather than dropping down to Ardverikie House (the main house in MotG) and having to climb all the way back out again there's a track that contours around the hillside to meet the current HT550 route at the new Hydro scheme on the river Pattack.
The track by the Pattack is pleasant though the best bit is now under the waters of the hydro scheme :roll: Eventually you get to the rickety bridge. Bad weather brewing over Ben Alder.
This is followed by what at first seems to be a boggy track. It's definitely much less used than that before the bridge, the only tracks seem to be from MTBs. The bogginess isn't really that bad, it's about 10cm of soil and peat overlaying the original hard surface so there's no hidden deep pools to send you OTB. By the time you get to the pillars (probably the boundary between the Ardverikie and Alder estates) you are back on good solid ground.
We dropped down to the back of the main house and followed the singletrack that avoids going through the grounds. It was just about now that the heavens opened.
The lochside track is great but Cath gets spooked by trails with a drop to the left. Not good when there's 14km of it!
Eventually you get to the first deer gate which has seen better days and is easily negotiated.
Beyond this the type 3 fun begins. I suspect that the stalker's track which we'd been following originally kept the same distance from the loch shore but with the damming of the loch the higher waters have eroded things so now it's right on the edge of a large drop onto rocks. Actually the original path has long gone, it's just the current line that does so. Quite why a line further up the hillside hasn't been opened up is a bit of a mystery, doesn't look anywhere near as bad. I've no shots from this bit - it was chucking it down and we were concentrating on not falling or dropping our bikes into the loch. It took nearly an hour to do 400m with lots of shuttling back and forth passing the bikes between us.
Once past the second deer gate you are on another well maintained path. Weird.
Being now soaked we elected to stop in the bothy which somewhat surprisingly was empty.
We'd been there an hour or so and had dried out when I spied a couple of bikers heading our way along the HT550 route. It turned out to be a couple of French lads. They didn't seem happy having "pushed for five hours through the swamp" - I suspect they might have taken the wrong track up from Loch Rannoch and had to squelch around the end of the loch as well.
The following morning was fair so we headed south through "the swamp" which only took 40mins but then we knew what to expect.
Rather oddly neither of us were looking forward to the big climb up the track afterwards but it turned out to be OK and not really a big climb, just our memory playing tricks on us.
Once at Bridge of Gaur it was some easy road (the only bit of the ride) up to Rannoch Station and the tea room.
Next up was another trail I'd not done: "The Road to the Isles". This started with a pretty big climb, a genuine one, that never seemed to end.
A stop at Corrour Old Lodge (an old shooting lodge derelict for over a century) which has amazing views over the Blackmount reservoir to the Glencoe hills.
Then it was descent time to Corrour and more cake.
Finally we picked up the original HT550 route again alongside Loch Ossian and down the Strath, which has more the feel of Canada than Scotland, back to the van.
The only one of "Phil's trails" that I've not now done is the Allt Cam linking Loch Pattack and Laggan. One for the fat bike methinks.
Re: Ben Alder Circuit (picture heavy)
:-bd Well done for doing the 'bad step' along Loch Ericht shore. I did it with an un-laden bike and really struggled at one point....
What was strange was that the track leading along the loch side had the feeling it was maintained - the edges of the uphill drainage ditch looked recently, as in the last couple of years, cut. Maybe the estate want to use it but aren't over keen on it getting too popular hence leaving the "bad gap".
Richpips
Post by Richpips »
Enjoyed that Bob. Thanks.
Dean
Post by Dean »
whitestone wrote: Tue Jun 07, 2022 9:05 pm What was strange was that the track leading along the loch side had the feeling it was maintained - the edges of the uphill drainage ditch looked recently, as in the last couple of years, cut. Maybe the estate want to use it but aren't over keen on it getting too popular hence leaving the "bad gap".
When I went from Loch Rannoch towards Dalwhinnie the loch was so low I skipped the whole deer fence section, clambered down to the bouldery beach and pushed, it was mildly easier than negotiating the eroding path.
Daniel
Post by Daniel »
Nice little route it looks, I like the tea stops!
I´m considering doing it next week but when you said you started at Laggan, did you mean the town or Loch? Then did you go West along the south of Loch Laggan then up to Earba to then back higher up Eastward along Loch Laggan, above Ardverikie then over the tops to Loch Pattack....
Does that make sense?
We started at the walker's car park by the estate track to Corrour http://streetmap.co.uk/map?X=243300&Y=783062&A=Y&Z=120 then up the track to the SW end of Loch Earba then cut east here http://www.streetmap.co.uk/map?X=251985 ... &ay=786329
The bit along Loch Ericht is fairly straight forward, might be a bit boggy in places now, but the bit between the fences here http://streetmap.co.uk/map?X=250737&Y=768085&A=Y&Z=115 is pretty dicey. Depending on weather you might be better heading over Bealach Dubh, i.e. reverse the route the Highland Trail takes. Another alternative would be to head to Dalwhinnie, follow the cycle route alongside the A9 to Dalnaspidal Lodge, along Loch Garry and down to Loch Rannoch, turn right and in a few miles rejoin the route we did. That would be gravel bike friendly - there's maybe 1km of level bog pushing after Loch Garry. Somewhere on here is an account of a winter circuit we did that included that - here you go https://bearbonesbikepacking.co.uk/phpB ... p?p=106320 I think my imgur account has been closed since the images aren't showing up.
A bit more intel here - https://philsbikepacking.blogspot.com/2 ... rides.html
I'm pretty familiar with the area so happy to give further route advice. I'd go with Bealach Dubh / Cumhahn over the Ericht shore path, even with a gravel bike as most of it goes pretty easy, apart from the climb...
Oh, yeah. The "rickety bridge" in photo 6 is no longer and is (well it was last summer) in a pile on the river bank. Fear not there's a motorway grade replacement.
The Wild Trails MTB book has the tour of Ben Alder going anti-clockwise from Culra over Bealach Dubh, at a guess there'd be about 500m of pushing up to the col. (It returns via a HUGE hike-a-bike up to the Bealach Breabag) There's a handful of burn crossings on the descent to the cottage that will need a dismount. Heading south from the cottage will be pretty boggy by now - I've only crossed it with nearly dry feet once, that was after a prolonged dry spell which we ain't had.
Not trying to put you off, just pointing out where the fun-type dial starts heading past 2 :lol:
Edit: Don't be tempted to short cut things by dropping down to the "track" following the Uisge Labhair down to Corrour. Full on heather bashing to get down to it and most is walkable at best with quite a few sections now in the river!
whitestone wrote: Sat Sep 14, 2024 8:33 am 500m of pushing up to the col. (It returns via a HUGE hike-a-bike up to the Bealach Breabag) There's a handful of burn crossings on the descent to the cottage that will need a dismount. Heading south from the cottage will be pretty boggy by now - I've only crossed it with nearly dry feet once, that was after a prolonged dry spell which we ain't had.
Bob, um, is there a nice sunny beach nearby with deckchairs and ice-cream and things?
:wink:
RIP wrote: Sat Sep 14, 2024 8:59 am
:wink:
Sunny? This is Scotland Reg.
Nearby? See answer above
Deckchairs? Been blown away down to Englandshire
Things? Plenty of them
:grin:
Dave B's winter passage of the Bealach Dubh remains one of the more horrendous experiences related on these pages, far worse than Steve Bates winter HT attempt!
I've never done the climb out the back of Ben Alder cottage, as it's always been horrible weather when I've aimed for it - the descent is meant to be even better than off the Bealach dubh.
fatbikephil wrote: Sat Sep 14, 2024 10:49 pm Dave B's winter passage of the Bealach Dubh remains one of the more horrendous experiences related on these pages, far worse than Steve Bates winter HT attempt!
This popped up on YouTube https://www.youtube.com/watch?v=7KvzuOVMOLg He avoids filming the climbs up to the bealachs. Descent from Bealach Breabag starts at around the 11min mark.
whitestone wrote: Sun Sep 15, 2024 5:04 pm
Cheers Bob, that pretty much ties in with how I thought it would be :grin: Defo worth a ride I think
