Hi,
Rebuilding a rim for my daughters bike and I’m after a rear hub. Ideally Hope Pro2 or evo but open to offers.
Thanks Chris
Sorted Thanks
Sorted Thanks
Re: WTD: Hope (or similar) 32h 135 rear hub
Hi Chris. I might have one fully built up. Happy to cut it out of the rim which is also a Hope if interested in the full wheel...
If Chris isn't interested Shaf, I might be. Assuming the rim is a 29"...?redefined_cycles wrote: ↑Fri May 06, 2022 10:08 pm Hi Chris. I might have one fully built up. Happy to cut it out of the rim which is also a Hope if interested in the full wheel...
Thanks Bob. Will keep you informed if he doesn't take it but I thunk it's a 27.5 unfortunately...Boab wrote: ↑Sat May 07, 2022 10:24 amIf Chris isn't interested Shaf, I might be. Assuming the rim is a 29"...?redefined_cycles wrote: ↑Fri May 06, 2022 10:08 pm Hi Chris. I might have one fully built up. Happy to cut it out of the rim which is also a Hope if interested in the full wheel...
Either way, I'd be interested in the hub...redefined_cycles wrote: ↑Sat May 07, 2022 11:06 amThanks Bob. Will keep you informed if he doesn't take it but I thunk it's a 27.5 unfortunately...Boab wrote: ↑Sat May 07, 2022 10:24 amIf Chris isn't interested Shaf, I might be. Assuming the rim is a 29"...?redefined_cycles wrote: ↑Fri May 06, 2022 10:08 pm Hi Chris. I might have one fully built up. Happy to cut it out of the rim which is also a Hope if interested in the full wheel...
Re: Sorted Thanks
Right then. Firstly, I'm really really really sorry. The 27.5 Hope wheel I have hung up in the shed is actually a front so I must have sold the rear at some point before (before what... maybe before I hit my head!!?).
But all is not lost... I have a set of hubs in 32h 100mm and 135mm. Shimano XT flavour. I believe the rear is unused and unbuilt and the condition of the spoke holes show this. The front looks as if it has been built at some point as the spoke holes are not as fresh.
I think I paid about £70 for the both from here last year but then managed to get some Hope hubs for the bike (sorry).
If Chris doesn't take then I shall pop up a price here...
