Help. Race Face ride fat crankset removal.
got a creak from bb area on my fat bike.
it is fitted with a race face ride fat crankset.
i s it removed via the single allen bolt on the chainring side ?
because i tried and couldnt undo it.
Re: Help. Race Face ride fat crankset removal.
RaceFace use a couple of types of self-extracting bolts.
1. Traditional style crank that needs a crank puller tool like this - https://www.parktool.com/product/univer ... anks-cwp-7
2. Self-extracting bolt that has an internal bolt that you unwind and when it does so it pushes against a cap. For this type you need either an 8mm Allen Key or a 6mm Allen Key, can't remember which fits the inner bolt, the external cap takes an Allen Key 2mm bigger.
Should be and they self extract the crank. They are FO tight mind so give a bit of welly. Oh and they might have used lock tight so mebbes put a heat gun on it for a bit
whitestone wrote: Sun Mar 13, 2022 8:38 pm RaceFace use a couple of types of self-extracting bolts.
It'll be the latter. 8mm Allen Key required. Don't remove the "cap" that uses the 10mm Allen key.
spinach for breakfast then and i shall have another go.
cheers all.
stevenshand
Post by stevenshand »
I have a RF Aeffect crank on a fatbike and it needs a crank extractor, 8mm bolt then a regular Shimano style extractor. That was specced as an OE crank though. That might make a difference.
Aeffects need a crank extractor (bolt on NDS) but the ride has the self extracting bolt on the DS
stevenshand
fatbikephil wrote: Sun Mar 13, 2022 10:18 pm Aeffects need a crank extractor (bolt on NDS) but the ride has the self extracting bolt on the DS
Ah, failed to spot it was a Ride. My bad.
