The Deadwood SUS is Salsa’s 29+ full-suspension short-travel trail frame. It’s designed to accommodate 29 x 3.0" tires, feature the true-tracking, Split Pivot suspension.
- High-modulus carbon fiber front triangle & aluminum seat stays with a tapered headtube
- Split Pivot suspension design
- 91mm rear suspension travel
- Designed to use tires ranging from 2.6" to 3.0" in width, on up to a 45 mm rims via BOOST 148 spacing
- Frame accommodates internal dropper post cable routing
Inc Sram BB & Nukeproof headset
Good condition. some small paint chips , touched up
£850
Collect, Cheshire or meet up
FS Salsa Deadwood Carbon sus 29+ frame Med
- 20211129_093358.jpg (70.62 KiB) Viewed 445 times
Re: FS Salsa Deadwood Carbon sus 29+ frame Med
What size is it?
Ignore me, I've seen it in the title now
(Too small for me, which is probably for the best)
