BB 200 OS Explorer maps
Is it pushing it to ask which OS Explorer maps I might need to buy to cover BB200 this year? It’s kind of too late once the route is published.
Re: BB 200 OS Explorer maps
…. I don’t object to buying a few more than needed if you want to keep an air of mystery
In all truth, I can't actually tell you just yet
Lovely bit of forward planning there Stu
No problems.
I have all the 1:50,000 maps I should need and now you’ve given me all the permission I need to over buy the Explorer’s
No problems.
I'm pretty much there with the 200 route but just a little unsure about a section that would push things over onto another map.Lovely bit of forward planning there Stu
Will there be a Spotwalla Spot Tracker Map that we can add our trackers too this year?
Nope and I'd ask that no one sets up any public on-line tracking for Oct as that will then put Nov riders at a potential advantage / disadvantage.Will there be a Spotwalla Spot Tracker Map that we can add our trackers too this year?
No worries!
Drat!Bearbonesnorm wrote: ↑Mon Sep 27, 2021 11:12 amNope and I'd ask that no one sets up any public on-line tracking for Oct as that will then put Nov riders at a potential advantage / disadvantage.Will there be a Spotwalla Spot Tracker Map that we can add our trackers too this year?
And I would have got away with it if it wasn’t for you pesky kids!
Explorer 201, 214, 215, 216. Add 217 for the 300.
Ah, most of Mid Wales then
I dont want to tempt fate (doh to late) but the weather in the run up to BB (around mid wales) is looking dry so far!!!! Hoorah!
I'd imagine it would need to be properly dry to get over all this recent rain, but I've not been in the area recently so I couldn't say for sure.Alexinthepeaks wrote: ↑Wed Oct 06, 2021 11:33 am I dont want to tempt fate (doh to late) but the weather in the run up to BB (around mid wales) is looking dry so far!!!! Hoorah!![]()
When I was in Keswick recently the Oxfam shop had a whole bunch of old OS maps for mid Wales so I picked up a 7 sheets. Hopefully when the BB 200 route gets put up Ill be able to plot it on the sheets. Better use of time than another Netflix series!
Is there a date when the October BB 200 will go out to riders?
Adi
Adi
- ledburner
the road won't have changed, unless the was a funding delay, so there's a few more Roman roadsoutonmybike wrote: ↑Wed Oct 06, 2021 10:43 pm the Oxfam shop had a whole bunch of old OS maps for mid Wales so I picked up a 7 sheets. Hopefully when the BB 200 route gets put up Ill be able to plot it on the sheets.
Adi
This weekend ... I won't be more specific because whenever I am, something generally crashes and makes me look a tw@tIs there a date when the October BB 200 will go out to riders?
Related, does anyone have a good option for Garmin maps? I'm sure I used BBBike last time but when I put them on my Garmin they don't seem to be loading.
Maybe I'm selecting the wrong type?
- In Reverse
I've got them off here for years Rich and never had a problem.
http://garmin.openstreetmap.nl/
looks like you can only select by country atm.
- ledburner
try https://talkytoaster.me.uk TT HD mapping
openstreet. maps in a 50k style with 25k detail.
very clear, lots of detail, but no over the top tourist info clutter. you can try some for free
worth a pint for u der £15, all UK mapping
- Screenshot_20211007_201827_org.mozilla.firefox_edit_30660585095320.jpg (119.42 KiB) Viewed 2484 times
They used to be the best, but if you actually try to get one now you notice that there are something like 80,000 requests in the queue. Tis dead.In Reverse wrote: ↑Thu Oct 07, 2021 8:17 pm I've got them off here for years Rich and never had a problem.
Cheers. I went with this one for now as I didn't fancy paying until I've got time to properly check them out.ledburner wrote: ↑Thu Oct 07, 2021 8:20 pm try https://talkytoaster.me.uk TT HD mapping
https://www.openfietsmap.nl/downloads/europe
* delete *
The Garmin link is a bit odd, you select "tiles" and the system builds a map for you. I used it for the maps for my 520 as that device is limited in the file size so you need to add/remove tiles until it shows something suitable.
For everything else I've used openfietsmap, got a few countries on the Oregon.
- In Reverse
