Stooge Mk2 complete bike with Rohloff hub
rosscopeco
Post by rosscopeco »
FOR SALE
Stooge Mk2 frame & forks
Freshly powder coated in Radberry
New decals
Hope BB
Raceface evolve cranks
SS chain
Freshly serviced Gravity dropper post
Charge saddle
Cane creek 40 headset
Nukeproof 40mm stem
Nukeproof grips
762 sunline flat bars
SLX brakes with 160R 200F disks
Hope Pro4 front wheel on 50mm scraper rim with Surly Knard 29x3 tyre
Rohloff internal hub rear wheel on 40mm Dually rim with On One chunky monkey 29x2.4 tyre.
XTR fromtnand rear skewers
On one seat post clamp.
Good points
Unridden bike since painting and rebuild.
Frame & forks in immaculate condition.
Rohloff hub serial No 076786 was bought and serviced by Ben Cooper of Kinetics here in Glasgow. This was the first Rohloff hub I bought…I’ve now had three and still run one on my Jeff Jones Plus frame. The hub has less than 10k miles ie it’s just broken in. It’s maybe had 1k miles over the last 3 years and has just had an oil change.
Twist grip & gear change cables are less than 100miles old.
The Hope Pro4 front wheel is in good condition and the Scraper rim has no dings and runs straight and true.
Not so good points
The Dually rear rim has seen better days. It’s in fair condition with several dings and marks but is relatively straight and true.
BB & headset could do with fresh bearings but they’ve been cleaned and re-lubed with marine grease.
Raceface Evolve cranks are well used with lots of side rubbing but are still solid and bomb proof.
Apologies for the only upside down photo. It's an Apple thing which I can't figure out so more high def photos are available on request.
£1600 plus postage.
Re: Stooge Mk2 complete bike with Rohloff hub
Strewth!
Strewth!
rosscopeco
Amazing! Thanks
Escape Goat
Post by Escape Goat »
Squibjib will or may be interested in this
rosscopeco
Now open to sensible offers - daft laddie ones will be ignored
sqibjib
Post by sqibjib »
Cheers escape
But it's a little bit to much for me.
Life is better on a bike
rosscopeco
Thanks for all the interest in this.
The Rohloff seems to be the stumbling block for everyone so I'll shortly be re-advertising the complete bike without the Rohloff but with 2 x 'normal' wheel sets. 1 x 650b+ 1x11 and 1 x SS 29er set.
