FS: Hope Pro 2 EVO hubs
They're blue. Just had the bearings and seals (seal) changed by laat owner. Bought em to shave weight but turns out these aren't as light as the PRO 4.
Cassette marks on the splines of the freehub with a nice ratchety feel (if thats your thing) and nice smooth bearings all round.
100mm front and 135mm rear. Both QR without skewers.
Front £50 ONO
Rear £90 ONO
Both prices posted and if you wanted both then £130 posted
Front £50 ONO
Rear £90 ONO
Last edited by redefined_cycles on Wed Aug 11, 2021 2:25 pm, edited 2 times in total.
Re: FS: Hope Pro 2 EVO hubs
NB. If anyone is buying to shave weight then these might be the wrong ones for you. Actual weight of the rear is 390g and not the 305g quoted online. Maybe its heavier grease or the axles/freehub has veen converted to a heavier one at some point in life...
Hey Shaf
Piccies to my email please
jaseisace71(at)gmail(dot)com
Jase
Jase
Sorry Shaf with your focus on weight, you've missed a couple of key specs. Number of spokes needed on each and are they disc or non disc?
Sorry... Yes, my badpistonbroke wrote: ↑Wed Aug 11, 2021 12:08 pm Sorry Shaf with your focus on weight, you've missed a couple of key specs. Number of spokes needed on each and are they disc or non disc?
32h (both)
6 bolt disc (both)
Pics coming up here just now
This will because it has a steel freehub, no? My alloy freehub Pro 2 Evo is pretty much 305g on the nose.redefined_cycles wrote: ↑Wed Aug 11, 2021 11:26 am NB. If anyone is buying to shave weight then these might be the wrong ones for you. Actual weight of the rear is 390g and not the 305g quoted online. Maybe its heavier grease or the axles/freehub has veen converted to a heavier one at some point in life...
http://imgur.com/a/2p28Dxu
Pics up there. I've checked the flanges for any hairline crack and I couldn't find any... so they're good to go
Last edited by redefined_cycles on Wed Aug 11, 2021 1:40 pm, edited 1 time in total.
Yes, I had a feeling about this being the case as it's the silver version and the cuts in the freehub are only jusy slight...Dyffers wrote: ↑Wed Aug 11, 2021 12:31 pmThis will because it has a steel freehub, no? My alloy freehub Pro 2 Evo is pretty much 305g on the nose.redefined_cycles wrote: ↑Wed Aug 11, 2021 11:26 am NB. If anyone is buying to shave weight then these might be the wrong ones for you. Actual weight of the rear is 390g and not the 305g quoted online. Maybe its heavier grease or the axles/freehub has veen converted to a heavier one at some point in life...
(goes to get out a magnet... honest answer = I'm not sure as the magnet is working and sticking to part of the acle ends. But when sticking to the freehub the magnetism is very very light which makes me think it's attraction to the bearings beaneath).
NB. Only reason for the weight-weenie wierdness is cos I'm using a used Halo carbon rim I had awaiting a rainy day. No point losing 100g on the rim but adding 110g on the hub
Pics added with a link to IMGUR jase... let me know if you can't see em
[Edit: I've started measur9ng em up for spokes so might not be available soon]
