Has anyone got an externally routed, cable operated 31.8mm dropper post they aren't using?
Cheers, Michael.
Wanted, Externally Routed Dropper Post
Bilbo Baggins.
Bilbo Baggins.
Re: Wanted, Externally Routed Dropper Post
I have a externally routed mk1 Reverb including bar lever that has seen little use so works fine (with a tiny about of sag/bob). It's 30.9 diam but I have a shim for 31.6 for the last frame I used it in.
Yours for £50 posted including the shim. Drop me a pm with your email address and I can do you some photos this evening if you're interested.
Bumpety...
Bilbo Baggins.
Bilbo Baggins.
I've got a 31.8x100mm Reverb if you would consider something not cable operated?
Thanks, but I am looking for a cable operated one.
Bilbo Baggins.
Bilbo Baggins.
Pretty sure you can buy a cable conversion kit for a reverb
Have a look at StartFitness - use code EXTRA10 at checkout - I just bought a Brand X one for £30 less than Chain Reaction
