Downloading Maps of huge routes offline to Mobile Phone ?
- stevewaters
Apologies if this has been done to death elsewhere ...
I usually load my planned routes to the OS Maps app on my phone and download the maps before I go and use this as a navigational backup on the ride.
However, for the Highland Trail 550, the GPX (separate out and back) routes cover so much land that my phone seems unable to download/store all the map tiles.
I can probably live with the 1:250,000 and get by without the 1:25,000 and 1:50,000.
- Anyone know a way of selecting out which scale maps are downloaded ?
If it is not possible on the OS Maps app, how about with Backcountry navigator or another app ?
Re: Downloading Maps of huge routes offline to Mobile Phone ?
You can download the maps for offline use in Komoot.
Blog - thecyclerider.com
Why not split the routes up into smaller chunks?
- BigdummySteve
If it’s a question of file size some applications only download the maps needed either side of your route, ridewithgps is like this I believe.
Steve, I did this off OSmaps onto my phone (Samsung A20) and whilst it took ages, and seemed to have hung at one point, it did download the routes eventually (i.e. the 'out' and the 'back' route) I'd already downloaded the necessary OS maps.
Now looking like the smart phone ain't going......
Have you got a phone with small storage space or is the OS Maps app very inefficient? I had the whole TD route and maps on my phone and don't leave the house without all of Wales and East Anglia stored locally at 1/10, 1/25 & 1/50. I use Back Country Navigator.
Viewranger is free and stores offline no problem. I downloaded both out and return into it.
Make sure to disable cloud storage if you’re using the iOS OS app. It is (or hopefully was) a fatal flaw that offline maps download to iCloud, so when you try to access them with no network coverage you can’t.
Ha, I've been having the same battle with OS maps and the HT route... I've been trying for a few weeks and it kept hanging. Now the app is telling me that the area is too big to download. Luckily I have the 2018 version of the Viewranger app which has all of Scotland loaded on the phone with 1:50k maps I bought a few years back, so I'll be using that. Not the most recent versions of the map and not 1:25k, but I have a lot more confidence it will work offline than OS.stevewaters wrote: ↑Sun May 16, 2021 6:57 pm Apologies if this has been done to death elsewhere ...
They really need to sort out the offline map issue with the OS app. Even small areas never work properly for me and it's a bad and possibly dangerous flaw. I didn't know about the iCloud thing though, so will try that.
Seconding Viewranger. It's basically built for this.
I always take my main route and download offline maps of the area I'm going to be riding in (so I can do shortcuts etc if plans change).
- stevewaters
Thanks everyone !
I have ordered a 32GB MicroSD card for my phone to get more memory and will then try the Viewranger app.
I've a 32GB card in mine so maybe thats how its worked. Viewranger was definitely better on the phone, but the desktop app was pants. OS is better on the 'puter but a right faff to download maps on the phone and tends to go blank at inopportune times. Smartphone out, bits of paper in for me for back up if (my) memory or GPS croaks.stevewaters wrote: ↑Mon May 17, 2021 12:17 pm Thanks everyone !
Still the same flaw!AlasdairMc wrote: ↑Mon May 17, 2021 11:52 am Make sure to disable cloud storage if you’re using the iOS OS app. It is (or hopefully was) a fatal flaw that offline maps download to iCloud, so when you try to access them with no network coverage you can’t.
This is what I find so infuriating about the OS app. It commands a premium over better functioning options that are cheaper.
- stevewaters
I have downloaded the Viewranger app and it told me I had to download the Outdooractive app too - they say they are linked apps, but it doesn't seem to be very seamless !
Viewranger only allowed me to download a small area of the whole route. I subscribed to Outdooractive "Pro" level but that doesn't seem to have helped.
Any suggestions of anything obvious I might be doing wrong ?
Not sure, but the merging with Outdoor Active filled me with dread... I’m still hanging onto the 2018 legacy app with bought maps that actually exist as a file on my phone. Sorry, that’s not much help!
- stevewaters
Thanks all !
I cancelled my Pro subscription to Outdooractive and went back to the OS app.
With the Micro SD card in and a huge amount of nurse-maiding (over 5 attempts for each), I finally got both legs of the HT550 downloaded to my phone so I will try to use that as a backup and to refer to if I need some mapping detail on route.
I'll ask again for clarity - why not split the route up into smaller chunks? Does that still overwhelm the OS App due to the amount of data?
- stevewaters
Beyond my technical competence which - as you may have gathered from the above is limited !ScotRoutes wrote: ↑Mon May 17, 2021 9:31 pm I'll ask again for clarity - why not split the route up into smaller chunks? Does that still overwhelm the OS App due to the amount of data?
I assume the total amount of mapping data is probably about the same, but more shorter routes (say 4 instead of 2) might have been easier to get the map data downloaded from the OS app.
The GPX files come from Alan and I am loath to mess with them. I did re-plot them using Strava routes but have made a few errors doing this with other routes in the past and don't want to risk a disqualification.
Definitely don't import into Strava. It will automatically break most routes.
With regard to downloading only a small amount, I assume you're downloading their premium maps offline rather than the free ones. I've never hit a limit on the free ones (and I downloaded basically all of Italy / Spain / France).
I've never had to download any companion apps though, so know knows what's going on there!
Edit - For info on what I do, assuming you're on Android.
Press the dots in the top right corner. Press "Maps". Select "Open" on OpenCycleMap. Press the layers button in the top right corner. Press "Save for Offline Use". Select the area you need (you may need to do this in stages if you need a huge area).
