Just to kick off some properly distanced rides for after the 12th....
12th April. Ride from where you are when you want. Around the NorthPeaks100 loop. I'll be starting at the Dewsbury end and it's rather nice is the loop (IMO).
Middle of May. Not sure which exact date. Planning to bivy somewhere near/at Bridlington then attempting to outrun the sun to Lancaster. Route is called Way of the Roses and its mainly/all road. Bit steep. I'll be headong out before the sun comes up as, if I remember correctly, it's much faster than humans so I need a good head start. If anyone wants to join at the start line then feel free
Dates for diary (NorthPeaks100 & Way of the Roses)
Re: Dates for diary (NorthPeaks100 & Way of the Roses)
Just a bit. Over 1,000 kph at our latitude.redefined_cycles wrote: ↑Tue Mar 23, 2021 1:56 pm. I'll be headong out before the sun comes up as, if I remember correctly, it's much faster than humans
Not so sure it's W/Kg is so impressive. Impressively consistent pacing though.Just a bit. Over 1,000 kph at our latitude.
