Hacks & Bodges
Leerowe76
Hacks & Bodges
Post by Leerowe76 »
Just thought I'd share this with you guys as I spotted it on the GMBN channel amused me a little but each to their own, I knows lots will engineer their own stuff and so.e will just purchase, let's see your hacks & bodges
https://m.youtube.com/watch?v=CdH6qIl7OLo
Re: Hacks & Bodges
cannot do photos but i fitted my front mudguards by attaching one side to the DT swiss bolt though handle and the other side to a 90 degree wall bracket [ cut short ] and attached to my lower flat post brake mount- its as stable as if done properly
its the best executed bodge I have ever done 1
Edit: Having watched love the wooden bike , handlebar thing looks overy compicated andliek it would foul wheel on full travel the last one - filler and unimportant
Re: Hacks & Bodges
Leerowe76
Re: Hacks & Bodges
Post by Leerowe76 »
:lol: that worked a treat for him
boxelder
Re: Hacks & Bodges
Post by boxelder »
That extra stem and bar thing just looks substandard without bags i.e most of the time.
Re: Hacks & Bodges
DIY pogies.
Mr conners
Re: Hacks & Bodges
Post by Mr conners »
I’ve often wondered why people mount their bars like that.
Re: Hacks & Bodges
Mr conners wrote: Sat Dec 05, 2020 9:40 am I’ve often wondered why people mount their bars like that.
It's cheaper than a trip to Dignitas?
Mr conners
Re: Hacks & Bodges
:grin:
Cheddar Man
Re: Hacks & Bodges
Post by Cheddar Man »
There is a chap who often cycles the Bristol to Bath railway path and he has tri bars clipped to (and you have to imagine this) the bottom of sort of backwards pointed butterfly bars.
The effect is that his arms are effectively through the butterfly bars, and his face is inches away from them. I often wonder how much damage he would do if he crashed, because he would snap his forearms and lose his teeth pretty much for starters!
Al
Re: Hacks & Bodges
Post by Al »
Just fixed my saucepan does this count? :-bd
(59.1 KiB) Downloaded 244 times
Squirrelking
Re: Hacks & Bodges
Post by Squirrelking »
Please tell me that's the threaded bar from an old headlock. Have you actually found a sensible use for one?
Mr conners
Re: Hacks & Bodges
Nice. Did you turn the handle? The wood looks very green.
Re: Hacks & Bodges
Mr conners wrote: Sat Dec 05, 2020 7:51 pm Nice. Did you turn the handle? The wood looks very green.
I hope it's green otherwise it's not bodging :smile:
Al
Re: Hacks & Bodges
Post by Al »
A random long Allen bolt and part from an old Allen key quick release.
The handle was just a bit of hazel off cut that was probably cut this summer so still green ish - someone usually burns through them with the gas cooker hob so I’ve made a few.
No turning - just a belt sander.
