WTD: 120mm 29er suspension fork
Blair512
Post by Blair512 »
Picked up some cheap 29er wheels to put on my Ramin 3+ so I'm looking for some suspension forks to use with them. 120mm travel, 9mm qr, 29/27.5+ wheel size, cheap!
Anyone got anything lying in the spares box looking for a new home? Don't need to be anything fancy, just a functional set of forks
Re: WTD: 120mm 29er suspension fork
I have a pair of Reba's but they are 100mm not 120.
Also they are taper steerer, and a short steerer of 175mm. Quick Release hub. In very good condition, white and serviced not long before they were taken off the bike.
They have sat in the garage now for a couple of years, but prior to that were fitted to my hardtail. I think they are about 2014, so 6 years old, but stanchions are immaculate.
Probably want as close to £100 as I can get. PM me. Check your steerer tube length!! (If you need a longer steerer I can gaffa tape a longer steerer tube onto the forks - should be fine until the 1st corner)
