Harness V Cradle help
GirlBikeVan
Post by GirlBikeVan » Mon Apr 13, 2020 8:08 am
I've been looking to ugrade my bikepacking gear. Have the Alpkit harness at the minute and it's been great but also a right faff with straps!
Done loads of research on The salsa Anything cradle and the Blackburn outpost harness and can't decide. Has anyone tried both? The Salsa Anything reviews talk of strap faffery but one solution is to use Voile straps.
I actually can't see anything wrong with the Blackburn Cradle. It's much cheaper, lighter, less straps and you can take the whole harness off to carefully take gear out on the floor. But not sure how big a drybag it'll take? 13L?
I love the fact that both sit away from the handlebars which is what i'm looking for.
I'm an occasional bike packer but do plan on some remote trips in the next few years. Maybe the Cairngorms loop.
Help me decide :)
Asposium
Re: Harness V Cradle help
Post by Asposium » Mon Apr 13, 2020 8:13 am
I have the salsa anything cradle
Initially for use on a drop bar gravel bike, and now for a hardtail mountain bike
Brilliant
Though not cheap, and likely heavier than a harness.
GirlBikeVan
Post by GirlBikeVan » Mon Apr 13, 2020 8:18 am
Nearly double the weight and price!
techno
Post by techno » Mon Apr 13, 2020 11:10 am
The revelate harness is rock solid. Look out for a 2nd hand one of those to keep the cost down?
https://www.revelatedesigns.com/index.c ... roductID=4
GirlBikeVan
Post by GirlBikeVan » Mon Apr 13, 2020 11:49 am
Cool thanks. This one is on my list too :)
Post by johnnystorm » Mon Apr 13, 2020 12:27 pm
Doesn't rub your headtube and fits low enough that lights and computer don't get blocked.
https://advntr.cc/straight-cut-design-h ... r-harness/
Blog, News, Reviews, Opinions, Routes: http://www.originaladventure.cc/
dnrc
Post by dnrc » Mon Apr 13, 2020 1:15 pm
i've used an anything cradle for a few years now where previously i had harnesses
the anything cradle has never given me any concern at any point, it just does it's job
strap faffery? they are a bit of a pain to put on but you only have to do that once when you first buy it, after that you just clip them together
Post by voodoo_simon » Mon Apr 13, 2020 1:55 pm
I’ve got the original* of that and it works very well :-bd
*Wildcat :wink:
Post by FLV » Mon Apr 13, 2020 2:03 pm
I have a wildcat harness, very good, very stable. Its done many many miles and never let me down.
I also have a Straightcut one, as i needed longer straps for my current bike, not used yet but front street test is positive.
I also have the acepac bar bag that stu sells in the shop here. Great value, works really well. Rode the tuscany trail with it and it never caused a single issue over 5 days.
Not a harness type though. There would be nothing to stop you using a seperate drybag inside the outer bag and just cinching it down though.
Post by Lazarus » Mon Apr 13, 2020 2:13 pm
do you have the roo pack for the alpkit?
once installed on the bike - 5 mins or less at home, then out on the trail you just release the strap on that to slide the bag out [ even with a 20 litre dry bag] and just slide it back in when finished and retighten.
Its not much different to straping up my apidura tbh - used for drop bars mainly
I have seen the blackburn one in a shop and it looks good and have the rear seat pack which i like and really rate
techno
Post by techno » Mon Apr 13, 2020 2:39 pm
One thing I notice about the Blackburn harness is that it places the roll out Infront of the bars. This is the worst place from a handling perspective and will also cast maximum shadow from your front light. The good thing about most harnesses is the pull the load in towards the head tube reducing the pendulum effect and minimising the shadow cast.
GirlBikeVan
Post by GirlBikeVan » Wed Apr 15, 2020 6:28 am
That's what I wanted to protect the cables. I have some great but funny shaped handlebars. Good advice though.
GirlBikeVan
Post by GirlBikeVan » Wed Apr 15, 2020 6:29 am
I'll have a look at that, thanks
techno
Post by techno » Wed Apr 15, 2020 7:59 am
i have oddly shaped handlebars too (ritchey kyote) and the spacers on the revelate harness provide enough space for routing the cables without kinking them even on full steering lock. EG:
the harness stu sells here has similar spacers: https://bearbonesbikepacking.co.uk/shop ... t=bar-roll
as do others:
https://restrap.com/collections/bar-bag ... -dry-bag-1
https://backcountry.scot/product/ortlie ... lebar-bag/
https://backcountry.scot/product/revela ... weet-roll/
https://backcountry.scot/product/revela ... pronghorn/
https://rockgeist.com/product/barjam/
https://www.lordgunbicycles.co.uk/speci ... rrency=GBP
https://www.mantel.com/uk/topeak-frontloader-8l
also, spacers are available to achieve the same result: https://backcountry.scot/product/drjon- ... ed-blocks/
Post by Lazarus » Wed Apr 15, 2020 12:02 pm
I can post it to you if you want to borrow the roo puch and see what I mean - i have the bigger one that actually holds stuff though I dont really put much in it - I seem to recall its pricey though so might be not much saving on a harness
If you can sew it should be easy enought to make one yourself as its basically a square with a strap on eahch corner
GirlBikeVan
Post by GirlBikeVan » Thu Apr 16, 2020 6:50 pm
That's nice thanks. I think i'm going to go with the Salsa. It'll last forever...Hopefully
Post by faustus » Fri Apr 17, 2020 9:27 am
Worth checking this, it's just been made available from Wildcat...
https://wildcat.cc/collections/accessor ... rks-g-funk
Those clamps plus a strapdeck (same site), and you have the same/very similar as a salsa EXP but cheaper
stevenshand
Post by stevenshand » Fri Apr 17, 2020 12:33 pm
I was just about to post this, so good job. I was thinking about putting together a package deal with the GFunk clamps, Strapdeck and straps for an additional saving.
techno
Post by techno » Fri Apr 17, 2020 1:15 pm
Great idea, as I just held off from ordering exactly that bundle :-bd
GirlBikeVan
Post by GirlBikeVan » Fri Apr 17, 2020 2:22 pm
The pack looks too low to me. And not as far away from the bars as the clamps on the Salsa allow which is the feature I like. Perhaps because of inexperience i'm splitting hairs A bit?
GirlBikeVan
Post by GirlBikeVan » Fri Apr 17, 2020 2:36 pm
Guessing you're the wildcat man? I'll hold off until you have a bundle deal too :)
Post by faustus » Fri Apr 17, 2020 2:39 pm
I guess it's personal choice really, but my thoughts are it can be rotated around the bar a bit to suit tyre/cable clearance needs. It looks like cables get more room than a harness with fork straps might? Also, weight closer to the bar might feel better, but I wouldn't know as i've not used something like this...just the cleanliness and secure fixing appeals to me.
Think i'll probably order one and a strap deck, as i have a few straps! :grin:
stevenshand
Post by stevenshand » Fri Apr 17, 2020 2:39 pm
Maybe, note that the whole thing can be rotated as much as you want so it would be perfectly possible to have it straight out the front. You could also use a bigger spacer (and longer bolt) to move it further away but I'm not sure what the motivation would be for that. For stability, I'd like it in closer to the bars, not further away (assuming clearance was ok).
GirlBikeVan
Post by GirlBikeVan » Fri Apr 17, 2020 2:48 pm
I've sent you an email asking about rotation on your website :)
My bars are a funny shape and i'm slightly worried there won't be enough clearance. I could get new bars tho. the ones I have only cost a tenner :-bd
restlessshawn
Post by restlessshawn » Fri Apr 17, 2020 3:33 pm
Think that's most of us on here too :wink:
That drjon thing could be just the job on my CX maybe...would have to shim up from 25.4 I guess
