I'm sure I seen somewhere you can attach water bottle cages to the sides of these.
Does anyone know if that's possible?
Mine will be going on some surly forks which have the 3 screw for mounted cages, I was hoping to add bottle cages to the forks as well.
Blackburn outpost cages info...
Re: Blackburn outpost cages info...
I've got 2 of these, 1 on each fork leg. They don't have any drillings or brackets for bottle cages, I guess you could easily fabricate a bracket which sits between the outpost and the holes on the fork to give you something to bolt a bottle cage to, bit like a pump mount.
Google is great ya knowLedburyjosh wrote: ↑Mon Aug 26, 2019 4:24 pm I'm sure I seen somewhere you can attach water bottle cages to the sides of these.
https://bikepackinguk.com/2018/07/13/bl ... ification/
Hadn't thought of doing this. Cheerstechno mail wrote: ↑Mon Aug 26, 2019 5:48 pmGoogle is great ya knowLedburyjosh wrote: ↑Mon Aug 26, 2019 4:24 pm I'm sure I seen somewhere you can attach water bottle cages to the sides of these.
OK cheers. that's kinda what I was thinking. was hoping it would bolt straight on to the side rather than need extending.
