Have been having a rummage and have some stuff I don't really use or have duplicates of.
So rather than hoard them, they need to find a new home.
Pole A Bear carbon pole - 1300mm long, 4 section, 360mm folded. 84g. Ex cond. £32.50 posted.
Pole A Bear carbon pole - 1000mm long, 3 section, 370mm folded, 70g. Ex cond. £22.50 posted.
Pole A Bear carbon pole - 660mm long, 2 section, 355mm folded, 44g. Ex cond. £15.00 posted.
The last two are a pair. I used them with my Rab/ Integral Designs Silwing tarp. They also work with a GoLite Lair, so should work with that type of shelter that is higher at the entrance and lower at the back. Would also work with a flat tarp. I would do the pair for £32.50 posted.
TalkyToaster 1:50K Look n Feel Full UK and Ireland Maps on 8GB Kingston Micro SD card. £17.50 posted.
Bought this in Feb and then got a S/H Garmin that came with the identical card. I was going to use it in an Etrex 30.
Comes with the print out key sheets.
13L Alpkit Airlock Tapered Dry Bag. Chilli (Red) colour. Well used but in surprisingly good nick. No holes etc. Comes with original strap. £12.00 posted.
Blackburn Outpost cage straps. 2 off, unused. The straps only are for sale! £5.00 posted.
Post up here, PM me or email mrbarry66ATgmailDOTcom.
PPG preferred or you pay the fees, up to you!
Email me for photos as can't post them up.
Many thanks
Adam.
F.S. Some surplus to requirements items.
- Laurensdad
Re: F.S. Some surplus to requirements items.
Email sent re pair of poles
Phil
Phil
@philg1971 Instagram
Hi Andy
Are the outpost for just the straps or Cage also.
Cheers Stuart
Cheers Stuart
Life is better on a bike
Stuart,
The Outpost straps are for sale only.
I will revise the original post.
Thanks.
Thanks.
Phil,
email sent.
Thanks.
email sent.
Thanks.
