Selling an unused Fox Rhythm 34 fork.
Boost axle std. Takes 27.5+ and 29/29+
Uncut steerer, tapered 1.5 - 1 1/8.
PM 160 mm direct.
GRIP damper, with adjustable rebound and compression damping.
Air sprung.
130 mm travel (can be reduced).
242.- gbp
Unused Fox Rhythm 34, 29", boost, 130 mm
Re: Unused Fox Rhythm 34, 29", boost, 130 mm
I cant afford at the mo but would have been all over these as the price is good and boost and 130mm is perfect...
Whats the 160mm in respect of?? Max adjustable travel?
Means 160 mm brake rotor size without and adapter - standard innit
Oh sorry... yes. Post mount. Thats tiny
Thanks for clarifying.
I'll keep your interest in mind.redefined_cycles wrote: ↑Thu Jul 04, 2019 10:02 pm I cant afford at the mo but would have been all over these as the price is good and boost and 130mm is perfect...
