Square taper crank set
Another question.
Any recommendations on a crank set to fit a square taper bb axle, please? I'm looking for reasonable, but not best, quality and if anybody has a second hand item that they would like to sell then I'd be interested.
The only thing I have to hand is a cheap Stronglight where the chainring is an integral part of the crank (sort of thing that is used on Bromptons) and it doesn't look very strong.
I will be running a single 38T chain wheel.
Re: Square taper crank set
Middleburn
try www.rjcx-treme.co.uk for best value on Middleburn stuff.
Also have a look at their Uno ring to go with the RS7/8 crank.
Thanks for that. I clicked the wrong one at first and came up with a heart attack price of £225.Ian wrote:Middleburn
try http://www.rjcx-treme.co.uk for best value on Middleburn stuff.
Is £125 for the RS7 about the norm for cranksets nowadays?
Last pair of cranks you'll buy, IMO :)
See also: http://ianbarrington.com/2010/05/12/full-circle/
Middleburn stuff is lovely but it does come at a price. The LX cranks in the top link would be a very good bet or failing that the FSA ones in the bottom link. I've used both before without problem ... the LX cranks are actually a bit of a bargain.
http://www.chainreactioncycles.com/Mode ... elID=86411
http://www.chainreactioncycles.com/Mode ... elID=90253
Note 170mm arms though - OK if you've got short legsthe LX cranks are actually a bit of a bargain
I'm twiddling 155mm's at present. I'll be able to lower the seat post :D
A quick google reveals Alivio square-tapers are under £30 and come with a 38T ring.
Aren't they riveted rather than changeable rings though?johnnystorm wrote:A quick google reveals Alivio square-tapers are under £30 and come with a 38T ring.
I've got a spa cycles own brand one. It was only 20quid and they claim that is made by sugino. It seems fine so far.
Chainreaction flog replacement rings so I hope not!nobby wrote:Aren't they riveted rather than changeable rings though?johnnystorm wrote:A quick google reveals Alivio square-tapers are under £30 and come with a 38T ring.
Thanks for all the help.
I finally decided to order the LX set from CRC. The Spa Sugino type cranks looked good until you add in chain bolts and a ring.
