Poor mans luna solo
Al
Poor mans luna solo
Post by Al »
I have a silly-light cat cut tart made by scotty the hammock guy that's great for the summer and when the weather isn't coming in sideways and an aliexpress trailstar clone that I've been very pleasantly surprised with in crap weather but is a bit massive for just me. What I really want is a luna solo, but sadly funds won't stretch currently.
Any way thinking of the trailstar I spotted this on ali express:
https://www.aliexpress.com/item/Ultrali ... dfe41929f1
Less than £30 and 410g
I realise there's no bug net and ground sheet light the luna solo but looks a bit of a bargain.
What do people think - too tall and likely to blow over? anyone actually have one?
Re: Poor mans luna solo
I really can't see any resemblance between that and a Lunar Solo.
Al
Post by Al »
As in, looks crap?
That kind of looks like a deschutes but seems to need 2 poles?? I thought they did one which was more of a direct copy of an LS as well as a version of the Deschutes...
Charliecres
Post by Charliecres »
I have a vaguely similar one-person Aliexpress shelter that came with an inner. The brand is Knot (same as my Trailstar clone). It did me well for seven nights in Scotland earlier this year (minus the inner). Might be worth seeing if it’s available, although the one you’ve linked to is probably fine too.
Charliecres
Mine uses one pole with no problems.
Teetosugars
Post by Teetosugars »
Al
Post by Al »
Charlie is the one teetosugars has linked the one you have? How tall are you?
Charliecres
Superficially similar but not the same. That one’s a different brand, it’s a fair bit heavier and is PU coated not silnylon.
firestarter
Post by firestarter »
The one nick linked to looks like my luxe mini peak 2 but half the price
Charliecres
Oh, and I’m 5 ft 9. It would be OK for someone up to about 6ft, I reckon.
I'd be slightly concerned by the guylines running off the apex - they either designed it in a belt and braces fashion or realised it was quite unstable later on :wink:
Al
Post by Al »
Stu, I see what your saying about stability, in some of the photos it looks really tall like it would blow over in a side wind.
Found the silnylon version:
https://m.aliexpress.com/item/328116379 ... 5028679330
Now I’m thinking my height 6’1” needs a bit of thought as I use an air mat.
Charliecres
Yes, that’s the same as mine
It's surprising how much room you'll lose with a separate inner - something that the Lunar scores well on by not having one. However, it's surprising how much room you'll gain by not using the inner :-bd
MikeW
Post by MikeW »
FLAME'S CREED 805g Oudoor Ultralight Camping Rodless LanShan 1 Tent 3 Season 1 Single Person Professional 15D Nylon Silicon
https://s.click.aliexpress.com/e/cLGsUf0d
This one Is a bit of a better colour
i have the first one linked to and it is fine in use - not tested it in super high winds but but have in blustery conditions [ fine if a little noisy] NB i use it in two pole mode- *IME you can just about squeeze two of you in there though its very cosy[ you will touch teh side during the night basically] and I [ 175 cm] can sit up in it[ just but its reasonably high]
For one there is tons of room including enough room for all your gear and still have space to cook
I use an inner with mine, but it weighs as much as the tent - though i can just use that in the summer heatwave.
If an inner is not mosi proof [ smaller annoying critter] rather than mosquito proof then it has no real purpose in the UK anyway so it is never somethign i care that
* much more space internally in this set up though i have used it with only one pole - personally [ for 100 g of weight] i would rather take the weight penalty for the space and security of two poles
YMMV
Bear in mind that a pole that's off-set / angled is weaker than a pole that's upright.
Al
Post by Al »
I’m thinking the nice green coloured flame creed and leaving the liner at home could be the way forward for me.
Hey stu, it says I need a 125cm pole - I have a 120cm pole of yours for my trailstar. Is it feasible to extend it??
Charliecres
FWIW I use the same pole for this and my Trailstar clone. Can’t remember if it’s 120 or 125., sorry.
I can make a 5cm slip-on extender if needed Al.
Al
Post by Al »
Magic - I’ll give it a whirl with what I’ve got first but that’s good to know.
Won’t be ordering til post festivities now - it not exactly a cheap time of year with 3 kids!!
Edit: didn’t take long for my patience to give way! I’ll report back when it arrives.
