Tomorrow, I shall be buying a ...
.. water transfer pump. I've just checked the spring at the Towers again this afternoon and it is no longer feeding the water storage header tank*, so what water we have in the tank is it. Long range forecast isn't showing any rain, so it looks like I'll be stealing it from the river ... yes stealing. I may own the river but her majesty owns the water in it. I reckon she'll not miss a bit.
*first time anyone can remember since 1942.
Re: Tomorrow, I shall be buying a ...
At least you've not told anyone you'll be stealing water. HRH will never know. Think she's more of a STW kind of girl
It really is the mid Wales desert!
Aye but everything's sort if gone a bit yellow rather than the usual green ... grazing shortage imminent no doubt.It really is the mid Wales desert!
Will you to purify before drinking it?
I did the welsh 3000s last weekend. Lots of dry streams, struggled with hydration (or weight of carrying water)
One of the few negatives to having a private water supply.
It's been about five years since we last ran out, similar weather to this but there were cows in the field with the spring and collecting tank and the buggers supped us dry! Mind you the grass looked like hay stood in the field so it must have been like a diet of cream crackers
Our lawn is looking a bit crispy. Might have to get the sprinkler out.
What sort of pump?
If I was thinking of doing the same but the muddy ditch at the bottom of the garden does not have any depth but does keep flowing.
So far looked at the ScrewFix Titan pumps and the Hozlok submersible but with nothing to submerse them in its a problem.
The ideal spot has Hornets next to it so the idea of getting in a digging a hole is a bit daunting.
Its also a 2 meter rise and 16 meter distance to pump water over and the drop off curve for pump efficiency is quite dramatic.
Buckets may be the answer.
Not to worry, there’s a bearbones ride at the weekend, bound to rain.Bearbonesnorm wrote:.. water transfer pump. I've just checked the spring at the Towers again this afternoon and it is no longer feeding the water storage header tank*, so what water we have in the tank is it. Long range forecast isn't showing any rain, so it looks like I'll be stealing it from the river ... yes stealing. I may own the river but her majesty owns the water in it. I reckon she'll not miss a bit.
I'll use it for other things first Ben ... and tea but it's boiled thenWill you to purify before drinking it?
Petrol driven Michael. They're usually quite happy to pump water that's not entirely clean. Even the smaller ones will pump a head of 30m or so.What sort of pump?
Is disappointed.
I'd hoped for some sort of weapon of mass (selective) destruction.
Plus a link in the bargain thread.
Blog - thecyclerider.com
It's a bit like a water cannon Rich.
yea, but Who did She STEAL it from Stu?Bearbonesnorm wrote:.. yes stealing. I may own the river but her majesty owns the water in it. I reckon she'll not miss a bit. .
Uh-oh. Tony, please don't start us on the "property is theft" debate again . Right, just off to bivi LNT on the lawn of our local stately home...
Never mind the rivers, who owns the rain that fills them?
You do Reg, hence the water board charge you to take it away from your property .... at which point they them own it and charge you to get it back.who owns the rain that fills them?
I have a 'dirty water' pump from Screwfix, think its a titan job. It pumps water from the bottom of my garden out into the drain, we have a problem with flooding (when it rains a lot, which its not at the moment clearly!)Mariner wrote:Re pumps, I have a 'dirty water' pump from Screwfix, think its a titan job. It pumps water from the bottom of my garden out into the drain, we have a problem with flooding (when it rains a lot, which its not at the moment clearly!)
Pumps water very effectively though a 1 inch diameter pipe, it's very impressive how much water it can get though. Just runs off the mains
I dug a hole and dropped a plastic box with lots of holes drilled into it and then dropped the pump into that. It'll pump water out with a couple of inches depth, it needs more depth for the float switch but there are ways to bodge that.
"Reg does" - Sort of a renting arrangement really - they get it back after I've used it, with a few scuffs and marks on it .
Stand by for the new Air Board, and the associated charging structure. Pay Per Sniff/Gulp.....
Its been a funny year weather wise. March, April our pond over flowing, however now no water just cracking mud, sludge.i dug a hole in it yesterday and the insects and birds were on it straight away as it drew in water from the surroundings
Did I have a stroke... what happened to the posts here?benp1 wrote:I have a 'dirty water' pump from Screwfix, think its a titan job. It pumps water from the bottom of my garden out into the drain, we have a problem with flooding (when it rains a lot, which its not at the moment clearly!)Mariner wrote:Re pumps, I have a 'dirty water' pump from Screwfix, think its a titan job. It pumps water from the bottom of my garden out into the drain, we have a problem with flooding (when it rains a lot, which its not at the moment clearly!)
pump.... stroke...... ARF!
Bugeilyn on a road bike?
Not far off. It's certainly far drier than when we rode it.Bugeilyn on a road bike?
It doesn't seem 2 minutes since you were snowed in
Trying to ride bikes.
Does the float switch just need to be vertical or does it need water?I dug a hole and dropped a plastic box with lots of holes drilled into it and then dropped the pump into that. It'll pump water out with a couple of inches depth, it needs more depth for the float switch but there are ways to bodge that.
Only need water to turn on and off. You can position it in the position you want and then just use a mains switch to turn it on and off. The float switch is basically a hollow box with a ball that moves inside itMariner wrote:Does the float switch just need to be vertical or does it need water?I dug a hole and dropped a plastic box with lots of holes drilled into it and then dropped the pump into that. It'll pump water out with a couple of inches depth, it needs more depth for the float switch but there are ways to bodge that.
