M4 Corridor Bikepacking (England)
Last week's #jennride was supposed to be my friends first experience of bikepacking, but alas his fitness and mountain biking skills were not quite up to the task and he pulled out of the ride sometime in the early evening. I've got the distinct impression that he feels pretty embarrassed about it so I'm hoping to put together something a lot more chilled (especially terrain wise) in the summer or autumn somewhere a lot closer to home for both of us.
With that in mind, does anyone know anywhere that might be good around the M4 corridor? I'm guessing something in the North Wessex Downs or the Chiltern Hills? Don't really fancy the Surrey Hills as in my experience it tends to be utterly heaving there.
Cheers.
Cheers.
Re: M4 Corridor Bikepacking (England)
I could sort something
Main problem would probably be timing. Calendar is pretty full with events at the moment so I'll have to work out where it actually fits. Stupid enjoyable life.
How about doing something around the Gower? It's lovely, feels fairly isolated but shouldn't kill anyone.
Inspiration from Mr Pease: http://www.anthonypeasephotography.co.u ... king-trip/
The m4 is most useful as a means of getting to south wales
I know the Gower well, but it's too far over for him... hence the England part of the title.
He's North London based and I just want to remove as many barriers to him coming out again as humanly possible.
He clearly lives in the best place in the world!
Chilterns are very easy to access, good for a bivy. Not flat but plenty of options to make it a bit easier
Sorry Richard, I'd just assumed he lived somewhere niceHe's North London based and I just want to remove as many barriers to him coming out again as humanly possible.
It's drier here than Wales!!
We might have a summer or autumn SE bivy in the chilterns, might work for that?
This was our winter one
https://www.strava.com/activities/80005 ... 1481495738
https://www.strava.com/activities/80005 ... 1481562779
I should be clear, he's not unfit by any means, but that lakeland ride was a tough one, especially in terms of terrain. He's a roadie normally so I'd wager it wrecked him both physically and mentally.
Edit - Ben, does that route have an appropriate amount of pub stops built into it?
Every cloud ...It's drier here than Wales!!
Has rain!Bearbonesnorm wrote:Every cloud ...It's drier here than Wales!!
I do seem to keep going back to Wales though...
We stayed in some private woods that trip but there are plenty of options round there if there's only a couple of you
Concern is mostly half decent routes rather than too much on places to stay. There's always a little clearing or field somewhere and as long as you rock up after dark and leave at first light you're usually golden.
Something involving The Ridgeway?
If you did want to come in thw general direction of the surrey hills but not into audi and enduro bike central I'd be hapoy to advise on a route- lots of trails that the majority of people on leith, holmbury and pitch will never ride.
For example if you wanted a point to point you could do a pretty decent route from Guildford tk sevenoaks along the north downs.
I think realistically it would have to be a circular route as getting back to the start would be a bit of a pain otherwise. Trying to remove any excuses for them to say no. :)
Do you have a rough idea of the sort of mileage/hilliness/amount of 'proper' singletrack you'd want to cover?
You'd be in the sort of area where you can drop in and out of towns easily so this may influence you one way or another if you want remoteness vs reassurance of a pub/shop. That said, I did 60 odd miles last Friday only really went as near houses as I wanted- there are plenty of places where you can look out for miles and see mostly trees.
I'd argue probably best to be no longer than 80 miles over both days, and realistically no more than 8,000 feet of climbing. I find that's a pretty good ratio as a general rule.
I imagine I'd want to avoid anything too rocky as it freaked him out a bit last time (I'd wager heavily rooted would have the same effect).
Not a real worry about masses of proper singletrack, as long as it isn't all deathmarch instead.
Ok, I'll have a think and see if I can come up with something interesting to give you an option
Tell us the start point and I'm sure we can work out some routes
Well, anywhere in that zone really. I guess somewhere in a rough circle between Swindon, Luton and Basingstoke.
