Taylor
Post by Taylor »
what on earth is that!?
Taylor
Post by Taylor »
A hangle.
:roll:
What's wrong with using the angle between your thumb and index finger? It's pretty much right.
He's just bought it to make sure I'm setting up right on Saturday ;)
Tanglefist
Post by Tanglefist »
Just received some black 2 mm 'bridle-line', cordage with a dyneema core and braided sleeve of...something else. 160 kg breaking strain, 3.6 grams per meters and 30 meters for a tenner from powerkiteshop.com
It has that 'new cordage smell'.
Brothersmith
Post by Brothersmith »
Droped off a couple of items - I blame Stu for both ;)
EnLIGHTENED Revalation x quilt by Brother Smith, on Flickr
Wanted to see what all the fuss about this quilt thing was and I use my curent bag open in the summer anyway so thought I would try with Revaltion x 40F. Seems to have avoided extra charges as well :D
Hope Pro II rebuilt on P35 rim by Brother Smith, on Flickr
Hopefully should spread a 2.4 tyre even wider and allow me to run at lower pressures on front with out weight penalty of going fat.
Taylor
Post by Taylor »
Camelbak Antidote 2L bladder.
Fits the Wingnut 2.5 almost perfectly.
restlessshawn
Post by restlessshawn »
A 29" wheel from Superstar and a 2.25 Ardent to go on it
Going to try tubeless again so expect lots of swearing later!
The postman has made a few visits recently, but I had to wait until my birthday before I could get them:
A silver Thomson stem so the collars and cuffs match on the Kite (pic to follow)
A pair PDW bird cages also for the Kite
A Jones H-Bar for the Pegasus
An alt-J CD.
Dan_K
Post by Dan_K »
Ian wrote:The postman has made a few visits recently, but I had to wait until my birthday before I could get them:
An alt-J CD.
I'll be interested to know how you get on with the Jones bar as i've been looking at them recently.
Alt-J rock too...... I've got their latest album too.
Ray Young
Post by Ray Young »
150x200x3mm alloy sheet to make a bracket for a MYOG bar harness.
Mart
Post by Mart »
An alt-J CD.
Love my Jones H-Bars, position feels much more correct then normal bars now
I fond the Ti ones take away more of the vibration than the titech ones.
A Hope SP Pro2 with Arch EX rim, Hope 34T chain ring and seat collar.
All destined for a b*stard experiment with existing gear including a 26 rimmed Alfine 11, a pair of On One carbon forks and either a Cotic Simple or Tinbred frame. I doubt it'll be pretty ;)
After a trip to Mat @ Ukhammocks to grab some tree straps (c.£7) for FF before last weekend's jaunt I am now also the proud owner of a Warbonnet XLC hammock. Rather a surprise and took my spend well over budget :o
Dan_K wrote:I'll be interested to know how you get on with the Jones bar as i've been looking at them recently.
Yes, will do. They look ideal for bikepacking, lots of hand positions and slightly more back-sweep/ upright position for all day riding. A custom bag to fit inside the loop is on the cards soon I think 8-)
Mart wrote:Love my Jones H-Bars, position feels much more correct then normal bars now
Even I struggle to justify the cost of the Ti ones :shock: ;)
InspiredRamblings
Post by InspiredRamblings »
s8tannorm wrote:
Whats the maximum diameter you think the clips would work to Stu?
Looking for extra water carrying capacity for summer, so wondering if they would cope with being fitted onto suspension forks?
The Monkii Clip is listed as fitting up to 38mm diameter. I've just tried it on a pair of Marzocchi drop offs with a slightly odd leg profile (not actually round) and with a diameter of around 40mm. I had to use a slightly longer bolt than the 2 supplied but it went on okay.
I think had the fork leg been round and 40mm, then the longest supplied bolt would have been fine.
I think I'm being dense here but just wanted to check - it sounds as if these probably DO fit normal suspension forks? I know sizes might vary a little but a lot of these type of things I looked at wont get anywhere near to fitting around a fork leg. I've got Fox 32 F120 FIT RLs on the Canyon. :-)
Salsa Horsethief XT (2020)
Jamis Dragonslayer (2016)
http://www.uninspiredramblings.com
An optimus Crux and an MSR Titan kettle.
Ill be sticking with the mug / meths set up for one nighters for brews etc but this brings me a lightweight gas set up for when I think I want to cook instead.
Jury is out on which is best (or none) for the highland trail
What diameter are the fork legs ?
The Monkii Clip (the bit required to fit a cage where there's no mounts) will fit 38mm and with the use of a longer bolt will go up to about 40mm diameter.
InspiredRamblings
I will have to go measure. They are 32mm forks but I don't know whether that refers to the diameter of the lower legs or the uppers...!?
32mm is the stanchion diameter rather than the lower legs.
InspiredRamblings
Ok thanks. Will get the tape measure out tonight.
Brothersmith
His just droped of a moosive Ardent 29 x 2.4 for the new P35 front wheel and some XO grip-shifters. Hopefully shifters will finally end my quest to find a set I like with my Jones bars :D
Brothersmith wrote:His just droped ... some XO grip-shifters. Hopefully shifters will finally end my quest to find a set I like with my Jones bars :D
Fitted my Jones bars last night. Didn't notice this problem ;)
Liking the shape so far, at least as far as a spin around the Estate has revealed. I'm already used to the backsweep from the Carnegies (and Mary's before those), but the slightly more upright position will hopefully help my shoulders/ neck on long rides. The out of the saddle position is a bit different, and might yet take some getting used to.
Taping up the loop with bar tape was an interesting exercise too...
InspiredRamblings
Ooh... photos?
I really (think) I want a set of these for an adventure bike. I'm using On-0ne Fleegles on my commuter which don't have the same degree of sweep, but do have more than a 'normal' bar. Just worried the sweep might be too much... Its a bit of a risk given they are fairly pricey.
Ray Young
Post by Ray Young »
InspiredRamblings wrote:
Ooh... photos?
I tried fleegles and found them to be too much like a standard bar. I now use Marys which you can get for £12.99. You could try a pair to see if you like the sweep before committing to Jones. Marys do have a rise on them though, I ride mine flipped.
