FS Wildcat Tiger & Alpkit Tapered Dry Bag SOLD
Chew
Post by Chew »
Having a bit of a sort out
Wildcat Tiger. One of the earlier versions and believe its a medium.
Used a few times and has the usual marks from use.
£50 posted
Never used
£15 posted
ianfitz
Re: FS Wildcat Tiger & Alpkit Tapered Dry Bag
Post by ianfitz »
I'm after one of the smaller ones. Will take it if so. Could you measure it for me to compare with the large one I have. Ta
Chew
Post by Chew »
What kinda measurements do you want Ian?
If it fits the Alpkit bag, it'll be a medium.
ianfitz
Post by ianfitz »
Chew wrote:What kinda measurements do you want Ian?
I'm after one of the ones which are now called Wayfarer and fit a 3-6L bag. The ones I have are 29cm along the underneath part of the harness.
Chew
Post by Chew »
Just measured the underside and its 29cm.
Dont know if the design has changed?
Back from 2012 and the invoice from Beth:
Size: Medium 4-8 litres
ianfitz
Post by ianfitz »
Chew wrote:Just measured the underside and its 29cm.
Ok Thanks for checking Chew but thats the size I have
Matt.........I will have that bag if still available.
Chew
Post by Chew »
Drybag sold.
Harness still available. £40 to match others pricing
seanroy
Post by seanroy »
I'll take the Tiger if its still available Chew?
ootini
Post by ootini »
Second dibs on this one, assuming second dibs arrives, and assuming I don't get seconds dibs on Ianftiz' tiger which I've already put second dibs on.....
Drliamski
Post by Drliamski »
Could I be third in line please!
:cool:
ootini
Re: FS Wildcat Tiger & Alpkit Tapered Dry Bag SOLD
Post by ootini »
Has this now gone?
Mike
Post by Mike »
I have a tiger if anyone is looking for one, it's not used anymore and a alpkit dry bags one tapered one and a 13l both kelp both as new.
mechanicaldope
Post by mechanicaldope »
Hi Mike. I still want these off you please. Was going to give you a call to meet this weekend if possible?
Mike
Post by Mike »
Sent you a message tom
seanroy
Post by seanroy »
Tiger received as described thanks Chew
