Carbon 29er forks with anything cage mounts?
Are the Salsa Firestater forks the only ones out there?
Don't won't to use extra clamps, so ideally would like them built in.
Re: Carbon 29er forks with anything cage mounts?
I think wisky#9 has the option as well
The prong is no longer on the website though to buy?
Whisky fork would be ideal but can't see it listed
I've Firestarters on two bikes. Can't fault them.
£500 for the firestarters that's more than Enve forks!
Email Michael, I'm sure he said he had some not long ago ... one of the nicest carbon forks I've ridden.The prong is no longer on the website though to buy?
Emailed - he has none left, he's waiting on the new boost forks but that would need a new wheel
Anything else out there?
Probably not what you're after but Gorilla clips work okay on carbon forks.Anything else out there?
If you started a similar thread on stw I've already said this but the gorilla clips were perfect on the TD. Didn't move at all and I had fitted normal cages, not free parable/gorilla cages.Bearbonesnorm wrote:Probably not what you're after but Gorilla clips work okay on carbon forks.Anything else out there?
