Lock
Lock
Any recommendations on a lightweight lock?
Re: Lock
Yep I use that exact one. I imagine it'd be easy enough to force it with a good yank, but it's nice & light & hopefully enough of a deterrent to keep the bike safe for quick trips into shops for a resupply etc
Re: Lock
Would anybody be interested if I could get a reasonable discount on a job lot of these?
Here's the blurb
"The Lock Alarm mini combination cable alarm is an innovative, portable devices suitable for securing any large items. When an attempt is made to cut through it's hard steel cable, or the main lock unit is attacked, a loud 100-120 decibel siren starts. The Alarm features a movement sensor that can be set to sound if the lock is disturbed and an adaptor to allow fitting to a notebook/laptop.The alarms cable length is 600mm and the lock body is 85 x 60 x 25mm."
I'm awaiting a call back on weight and possible discount for a bulk buy.
Regular price is £15.99 plus postage.
Re: Lock
yer put me down FF It would also have many many other uses outside of cycling, double bonus :)
G
G
Re: Lock
hmm I could be interested in one of those too. I wonder how much it weighs... :D
Re: Lock
Weight is 100g
Re: Lock
cheers!
Re: Lock
http://www.pcworld.co.uk/gbuk/retrak-re ... x&istBid=t
£12.00 and free delivery from PC world!!!!
I'd have to buy 50 to get it as low as £12
Re: Lock
I've always gone with the Monkey Puzzle lock.
This involves clipping your helmet through the wheels, another bike, tying a jacket arms through another bit of the bike and draping the body of the coat over the helmet etc. Clip rucksack straps through and around stuff.
Basically make it awkward, then keep bike in view.
Steve also added to this 'making it awkward theory' by knacking the gears. Once its parked up either drop all the gears on the thumb shifter or up them so that if somebody does try to ride off they are faced with jumping gears/dropping chain*.
*Don't forget about this if faced with immediate uphill as I did
Re: Lock
I wonder how much a tiny padlock and cable would weigh in comparison to one of those retractable jobs.
I've got a tiny Abus lock I'll weigh tnt out of curiosity, along with 2' of brake cable.
Re: Lock
Bit tricky with a SS :?Steve also added to this 'making it awkward theory' by knacking the gears. Once its parked up either drop all the gears on the thumb shifter or up them so that if somebody does try to ride off they are faced with jumping gears/dropping chain*.
Alternatives:
- Bit of a faff, but you could remove the pedals and put them on the inside of the cranks
- Add fat ziptie somewhere on the drivechain to stop it going around.
- Ziptie the front wheel to the fork crown/ leg. (remembering to remove it before you set off again).
- Slacken your quick releases or your seat QR
- Small padlock through the disc rotor like they do on motorbikes
But as Matt says, keep it in sight if possible.
Re: Lock
Those pc world ones look like they are for locking a laptop down, laptops usually have a small slot which the lock fits into and the end turns 90¤, I suspect it would not lock back on itself to form a loop. May be worth a trip to pc world to have a look before splashing the cash.
Edit, seems that it does format a loop and I'm talking crap. See here
http://www.retrak.co/Products/tabid/86/ ... fault.aspx
Re: Lock
I reckon I may go for something a bit more secure, got a 80g sil nylon duffel to stash all the frame bags in, just need something secure but not ridiculous, I reckon something a little more secure
So far Knog Fisticuffs is winning
http://www.chainreactioncycles.com/Mode ... elID=58689
Re: Lock
You mean in terms of being the heaviest, right?So far Knog Fisticuffs is winning
Re: Lock
Need something a bit more than retractable lock, something that will really make someone think twice. Would you trust your bike in a town to thy lock?
Re: Lock
I don't think locks for leaving a bike in a town centre is the usage being discussed, more something that can be carried and used for nipping into a village spa to restock.
Anyway my solution would be to concert to a fixie, then you could really laugh as the thieving scrote nearly kills himself.
Re: Lock
The village shop the retractable one will be fine, but I'll probably have to enter proper shops in the alps for resupplying, that's my issue. Will also have the bike with me in Chamonix. So the retractable although great for the village shop, I'm going to have to beef up for towns.
- VeganGraham
- Location: The sun dappled leafy glades of Worcestershire
Re: Lock
Thread resurrection, I'm surprised this doesn't get discussed more often.
I've been using the old 'upturned bike as a tarp support' method of overnght security. Hopefully if someone takes the bike, the tarp falling on my face would wake me up.
I want to use my hooped bivi though, which would mean leaving the bike alongside me overnight. I can take the skewers out and hide them, but that doesn't stop someone walking away with it in pieces.
Any opinions on this for £30, apart from it being big & heavy?
http://www.sjscycles.co.uk/lock-alarm-4 ... -prod3960/
Or there's this for £4, although it could probably be snipped through quietly with a multitool while I sleep.
http://www.amazon.co.uk/3-Feet-Retracta ... B00B215PHE
Is there any sort of motion sensor alarm that could be used in combination with a cheap cable lock? All I can find is PIR ones for insecurity lights or car alarm add ons.
Is there a self contained unit that could be attached to a bike?
Worcestershire's fastest veteran vegan mountain bike endurance racer with a beard.
Re: Lock
That big cable lock from SJS looks pretty good
I use a Knog Milkman - needed something small and compact for the odd cafe or shop stop. Have a few other Knog silicon covered cable locks that I could use if I'm really worried
I initially had a pound shop cable lock, works fine, probably lighter than the knog milkman, butess good from a build quality and neatness perspective. Good for emergencies though
Re: Lock
When I lock up @ the supermarket, I take the front wheel out and lock it to the back wheel/bike rack and take the axle with me. Be an adventurous ride for the thief with no front wheel in place.
Re: Lock
I know I'm probably fortunate but I do believe that, if you're worried about someone nicking your bike during the night ... you've pitched up in the wrong place.
Re: Lock
Gabes and I got the cheapo ones for the Cambrian 500. One of three broke straight away, but the others were fine so try before you take it out with you. I'm sure they are pretty feeble but enough for a pasty and milkshake grab from the Spar. I also have a Knog Party Frank which is a silicone covered cable lock. A bit more secure, not too heavy and the silicone stops your bike getting battered and the lock rattling against stuff in your frame bag.VeganGraham wrote:Thread resurrection, I'm surprised this doesn't get discussed more often.
Re: Lock
I carried a Krptonite cable and an old combination padlock that I had lying around when I went touring.
Stuart is right though.
Re: Lock
+2Bearbonesnorm wrote:I know I'm probably fortunate but I do believe that, if you're worried about someone nicking your bike during the night ... you've pitched up in the wrong place.
But if you search 'personal alarm' on fleabay & amazon there's plenty of choice for one with either a pin-pull, that you could attach to something with some fishing line, or there's even some motion sensor type ones that you could leave inside bike luggage..
