29+ forks
29+ forks
Hi all
Looking at getting a 29+ frame and forks the only forks I can find are the manitou magnum 29+ does anyone no of anymore out there or if any standard 29 forks fit?
Thanks Paul
Thanks Paul
Re: 29+ forks
I have a set of niners which run a chronicle in them with room to spare
Re: 29+ forks
Whisky forks look nice. There is also a enve form as well. Both ££££ though.
Re: 29+ forks
I was assuming given mention of Manitou Magnum, that we were talking suspension forks .... if we're talking rigid, them most 29er forks have enough clearance.
Re: 29+ forks
suspension forks.
MRP Stage
Manitou Magnum - Need boost 110 front hub
2016 Fox 27.5+ also fit 29 plus - Need 110 hub
2013 Fox F29 - 29+ fits, but recommend summer use only personally
There are spacer kits to adjust 100mm front hubs to boost 110mm
I use rigid for 29+ but occasionally suspension, when I do, I fit a panaracer Fat B nimble tyre as its only 2.75" measured.
Rigid, what they said. I have a whiskey No 9
MRP Stage
Re: 29+ forks
Having used the 2013 Fox forks with a 29+ setup may I concur that you don't want much mud going on at the same time. Space is....precious with some tyres.
Re: 29+ forks
Yup, hence the preference for the smaller panaracers.GregMay wrote:Having used the 2013 Fox forks with a 29+ setup may I concur that you don't want much mud going on at the same time. Space is....precious with some tyres.
- mountainbaker
Re: 29+ forks
Those panaracers are crap though. Mine lasted 2 weeks before a 2 inch slash in the flimsy sidewall.
Re: 29+ forks
you certainly cant run them as low a chronicle or knard pressure wise.
I've not wrecked mine yet, though they are on the floor in the shed
- JohnClimber
- Brothersmith
Re: 29+ forks
Second the Travers bike fork, can also get it with anything cage mounts.JohnClimber wrote:http://www.traversbikes.com/store/c1/Fe ... y=15761046
There is also the Lauf Trail Racer Boost fork if your not sure if you want suspension or rigid
