Go Lite Shangri la pole replacement
Hi has anybody replaced the heavy wide dia. Easton pole on a go lite Shangri-La/ hex with a carbon pole or similar? I think the pole has to be 5'3". I am trying to strip down this tent to its possible lightest weight for use in open country. Any link or advice appreciated...
Re: Go Lite Shangri la pole replacement
160cm is quite a length and a lot to ask of a lightweight pole. However, with an increase in diameter, there's no real reason why a carbon pole couldn't be used. It would certainly offer a decent saving in both weight and pack size but would obviously come at a price.
I haven't looked for it, but I wonder if Mountain Laurel Designs make one to go with their Supermid
I have a Supermid, actually an earlier version, which I pitch with two carbon walking poles attached to each other. It's surprisingly tall, I would imagine similar to a Hex/Shangri La 3
Nope ... but I believe there's a man in Wales who could make one.I haven't looked for it, but I wonder if Mountain Laurel Designs make one to go with their Supermid
The SL probably weighs quite a bit more than a Supermid, so more stress on the pole.I have a Supermid, actually an earlier version, which I pitch with two carbon walking poles attached to each other. It's surprisingly tall, I would imagine similar to a Hex/Shangri La 3
I'm positive you could! I was all set on commissioning one so I could take mine as a tent on my motorbike, but the trip isn't likely to happen for the foreseeable so no need for it now!Bearbonesnorm wrote:Nope ... but I believe there's a man in Wales who could make one.I haven't looked for it, but I wonder if Mountain Laurel Designs make one to go with their Supermid
Do you make some sort of link or similar to be able to join poles together? I wonder if it might be too flexy/high risk though. I'm thinking of joining up the 110 and 100cm poles together, or maybe add a little jobbie to the top to make them up to 170cm (for example)
No, I don't Ben. Once pole length starts to go beyond 120cm or they're for a high stress shelter like a TrailStar, I alter some of the dimensions to up the load capacity ... you're right, lashing two shorter poles together isn't idealDo you make some sort of link or similar to be able to join poles together? I wonder if it might be too flexy/high risk though. I'm thinking of joining up the 110 and 100cm poles together, or maybe add a little jobbie to the top to make them up to 170cm (for example)
The SL probably weighs quite a bit more than a Supermid, so more stress on the pole.[/quoteBearbonesnorm wrote:Nope ... but I believe there's a man in Wales who could make one.I haven't looked for it, but I wonder if Mountain Laurel Designs make one to go with their Supermid
Thats good to know. Theres life in the flysheet and im getting a one man inner with some LW pegs. So I should get a few years of LW careful use of it before investing in something new. Ill message you.
Shangra la and Supermid are a similar height 170-175cm so long pole.
I've been doing a bit of digging and Black Diamond used to sell a carbon pole for their pryamid tent that was 18mm outer diameter carbon, whether that was overkill or not I don't know.
