Radnorshire
- godivatrailrider
Radnorshire
I'm hoping to do a route in Radnorshire ..... I'm sure it's been done plenty of times before ... does anyone have any route suggestions?
Re: Radnorshire
Anywhere in particular? Length, number of days, etc?
- godivatrailrider
Re: Radnorshire
Probably just a 2 day / 1 night route. Sort of Kington, Knighton area.
I've worked out a 60miler 8000' route which sounds about right. Needs work and local knowledge though...
Re: Radnorshire
iv had a nice route from new radnor but could do with Ians input to extend it alittle more. its currently around 40miles i think i can email u the gpx if u pm me
Re: Radnorshire
The trans cambrian way heads west from llanfair waterdine which is just outside of knighton, you could fit some if the in before cutting back south to radnor. You may want to keep an eye on the weather as lots of the trails are grassy and pretty sapping in the wet.
- godivatrailrider
Re: Radnorshire
There is a hefty bridleway from Lloyney (which is pretty much llanfair waterdine ) to Llanbadarn Fynydd ... can't easily identify it on google maps, though the OS map may show it.tremonti wrote:The trans cambrian way heads west from llanfair waterdine which is just outside of knighton, you could fit some if the in before cutting back south to radnor. You may want to keep an eye on the weather as lots of the trails are grassy and pretty sapping in the wet.
