My front wheel has gone a bit grindy so I've been having a look tonight, any tips on how I get the bearings out?
I've got access to a bearing press and puller but what's the deal with the sleeve that's protruding, how does that come out so I can use the puller on the inner race, does it need a tap from one side?
Hope the pics work ...
https://flic.kr/p/2pAr4Kb
https://flic.kr/p/2pAskG6
Replacing wheel bearings
Re: Replacing wheel bearings
Yup. Just a light tap AFAIR. Knock it towards the disc side...
This should help. Excellent mechanic/teacher is this lad.
https://youtu.be/tZBvxt967c0?si=QzRHsWonxH8X6aRn
Main thing is to get some quality replacement bearing Rich. Fag orNTN/SKF etc. Beware of copies. Enduro bearings are ***t, IMO.
Hammer use a rubber one or wood to protect the soft alloy
IME they often take a fair amount of whacking to get out ( and take the bearing with them)
