Evening,
I was about to replace my front hub onto a wider rim before I realised 24h and 32h aren’t compatible (easily)! Ooopps and bugger.
Does anyone have a cheap complete front wheel (27-32mm ID ideally) for sale in 15x110 (or 100) as I’ve got adapters. Or just a hub?
Thanks Chris
WTD: boost 29er front wheel
Re: WTD: boost 29er front wheel
Pretty sure I've got a SRAM Roam 30 wheelset sitting in the basement. 110x15 front, 142x12 rear.
I have a front SRAM boost hub black 32 with that propriety SRAM interface good for rockshok forks but won't fil all forks ( cheap though)
Thanks but would need it to fit other forks sadly.
Thanks Greg, dropped you a message.
Chris
Chris
