FS: Sinewave Beacon + SP Dynamo Wheel (reduced)
Wheel still available £115 collected.
Selling my little used Sinewave Beacon light, in excellent condition.
(tape around the light is my way of 'strain relief' to the wire coming from the back of the light)
Bracket included. Connection wire included.
Must sell with the wheel with SP Dynamo hub PD8X (Disc and 15x110mm) Velocity Blunt SS rim (29er Wheel) and currently has a Wolfpack Speed tyre (I can remove if you don't want the tyre).
All was supplied and wheel built by Shona and Rich over at Keep Pedalling.
£375 Collected from Glossop or Nuneaton on specific days. Delivered locally around those areas. NOW £325
I may even clean it
Excellent condition, probably only has 300km on the pair. (Tyre has done more)
Beacon light link
https://www.sinewavecycles.com/collecti ... les-beacon
SP Hub Link
https://www.sp-dynamo.com/series8X
Bracket
https://www.sjscycles.co.uk/lighting-sp ... g-bracket/
Rim
https://store.velocityusa.com/p/blunt-s ... _atb?pp=12
I may even clean it
Beacon light link
SP Hub Link
Bracket
Rim
- ledburner
Re: FS: Sinewave Beacon + SP Dynamo Wheel
What's size wheel is it?
Where did you get the mount from ?
I have one and that looks better than what i use
For anyone curious its a great light and I like the fact its a dynamo light, its a usb charge and its a battery light[powerbank] and you can do charge through - ie use the light on dynamo or battery and charge the battery bank at the same time.
Fair Point Its a 29er. Hub is 110 x 15mm and Disc
The whole lot came from Rich and Shona at Keep Pedalling. The mount is double so fits either side of the stem. Shona reckoned it would work single sided too.Lazarus wrote: ↑Mon Mar 27, 2023 12:50 pm Where did you get the mount from ?
Link added above.
thanks for the info mines a keeper, commute all year round using it on dynamo and then can get through the night with a reasonably light power bank when on the MTB/bikepacking.
Re: FS: Sinewave Beacon + SP Dynamo Wheel (reduced)
Do you still have this item? Would you consider posting it?
“‘What day is it?’ asked Pooh.
‘It’s today,’ squeaked Piglet.
‘My favourite day,’ said Pooh.”
PMed you
Life is better on a bike
Mail is playing silly buggers I will email address to you cheers Stuart
Cheers Stuart. I thought as much as a message of mine had been sat in the outbox for ages.
Sorry guys, I have been rubbish at checking back on here.
Lamp is sold, wheel still available £115 for the wheel. Collected.
