Side release buckle with cam - UK supplier?
- thenorthwind
Anyone know where I can get hold of these side release buckles with an integrated cam to lock the strap, in the UK? https://www.extremtextil.de/en/side-rel ... r-cam.html
I have something similar on my Blackburn seatpack harness, and I like them. Seem to be rarer than a rare thing though.
Re: Side release buckle with cam - UK supplier?
Not sure if they have exactly what you need but it might be worth a look https://www.contactleft.co.uk/diy-tacti ... brics.html
Will putting the cam lock on seperate work? If you got a good buckle it should lock itself I thought/found?
https://www.profabrics.co.uk/collection ... cam-buckle
- thenorthwind
Haven't come across them before, thanks. Can't see anything suitable though.samwise wrote: ↑Tue Sep 27, 2022 6:32 am Not sure if they have exactly what you need but it might be worth a look https://www.contactleft.co.uk/diy-tacti ... brics.html
It should, but the cam lock gives a bit of extra security when you're putting a lot of tension on them. A separate cam lock should work, though I'd have to figure it out, but the combined buckle is a nicer user experience.redefined_cycles wrote: ↑Tue Sep 27, 2022 7:36 am Will putting the cam lock on seperate work? If you got a good buckle it should lock itself I thought/found?
Let me know when you find please Dave. I'll pop one on my Endura (2nd home with me) singletracks. The buckle seems to have lost its grip and slips...
I know Alpkit use these on some of their bags. Could be worth an email to see if they have any spares you could purchase?
- ledburner
Hi shaf, a temporary alternative method is to add a little inner tube patch or trimmed inner tube patch.
Under the cam to add friction
It sounds like the cam teeth have worn or distorted.
Thats great thanks Dan. That'll do for me and will report back... maybe its just mt belly that can't be contained!
I got something similar from Andy at BackcountryScot
Revelate do a spare buckles. There is a cam lock listed
https://backcountry.scot/product/revela ... s-buckles/
Have you considered a metal G-hook buckle? I have one to replace a broken plastic cam buckle, did not require any sewing to attach.
