GPS Again
- rocklobstercat
GPS Again
I'm after a GPS device and have been looking at the Garmin Etrex 30 or Garmin Dakota 20. They both look very good with similar features. One is touch screen the other isn't. Has anyone got any experience with either of these or advice on which one to go for?
Re: GPS Again
I have a Dakota 20 at the moment and had an eTrex 20 before that ... I find the Dakota a much easier unit to use. The screen's bigger and it works okay with gloves on too, I find the whole thing pretty easy / straightforward now I've had a good play with it.
I believe that battery life isn't quite as good as the eTrex but I've not found it a problem.
Re: GPS Again
Can you download free maps from the internet onto the Dakota 20?
- rocklobstercat
Re: GPS Again
Cheers Stu, what's the screen quality like on the Dakota compared to the Etrex?
Re: GPS Again
Somewhere on here there's a link to buying an sd card that contains full UK OS mapping for about £25 - I was a little sceptical at first given what Garmin charge for the same thing but in reality it's superb.Can you download free maps from the internet onto the Dakota 20?
I think the eTrex has a slightly higher resolution but the Dakota is fine, slightly fuzzy but certainly good enough to navigate with, even when you're travelling at speed.Cheers Stu, what's the screen quality like on the Dakota compared to the Etrex?
Re: GPS Again
It probably comes down to whether you want a touch screen or not, I hate them so got the etrex 20. The cheapo garmin maps are perfect.
One pair of alkaline AA batteries lasted me the whole WRT weekend and 2 rides when I got home!
Occasionally if you are going fast down a hill it will struggle to update the map square quick enough if you are zoomed in...however if you are going that fast then trying to read a tiny map on your bars is not advised
Re: GPS Again
Another happy Dakota & iOffer maps user here. The key to battery life is playing with the screen brightness. A few notches darker, that you'll barely notice, has a big effect on battery life. On full brightness its about 3 hrs from a pair of fresh 2900mah AAs. With it still perfectly readable but turned down as much as possible I get a day and a half of riding out of the same batteries.
- rocklobstercat
Re: GPS Again
I read somewhere that the Dakota screen is hard to read in daylight compared to the Etrex. Any thoughts on this anyone?
Re: GPS Again
Can't say I've had any trouble really.I read somewhere that the Dakota screen is hard to read in daylight compared to the Etrex. Any thoughts on this anyone?
Re: GPS Again
I have a Dakota 20 and cant really fault it. Easy to use, screen readability is fine and if you play about with the settings you'll get best part of 2 days out of a set of batteries.
No issues using it with gloves on, and anyone having issues might want to calibrate the screen while your wearing your gloves as you contact point may be different than just using your fingers.
Mines taken alot of abuse as well and still works. Hours of rain, self ejecting (crap mount) and getting either whacked against rocks/being run over.
Re: GPS Again
This thread comes at an appropriate moment for me as was just considering a unit.
Anyone seen it cheaper than c.£150 on Amazon?
Re: GPS Again
Cheers. Amazon also do 7% cash back through Quidco.
Sorry for the slight thread hijack OP but hope it's the same sort of info you'd want anyway 8-)
- rocklobstercat
Re: GPS Again
I'm still torn between the Etrex 30 and Dakota 20. Can anyone comment on screen quality of both of these devices please before I take the plunge :?:
Re: GPS Again
I think that what the Dakota loses* on resolution it makes up for in size.I'm still torn between the Etrex 30 and Dakota 20. Can anyone comment on screen quality of both of these devices please before I take the plunge
*which isn't actually that much in the real world.
Re: GPS Again
If I had to choose I think it would be the Dakota.
Re: GPS Again
I've just thought, the screen on the Dakota can't be too bad ... because I'm completely colour blind and can read it. Often things like screens, etc I really struggle with. :D
Re: GPS Again
Having used one of the little Edge personal GPS / bike computer thingies for all of about 3 rides and then losing it (most irritatingly somewhere at home I reckon) have blown the cash and got a Dakota 20 from Amazon.
Getting the cheap 1:50k mapping is all to cock though as Paypal have "limited" my account. Goaddamn them, don't they know who I am :evil:
- rocklobstercat
Re: GPS Again
Cheeky Monkey I would be grateful of your opinion on the Dakota 20 when you get it. I'm on the verge of buying mine very soon.
Re: GPS Again
No worries. I've used a really old Etrex before (no mapping) and found the buttons and OS a pain. Ridden with others using the Dakota (FF) and was struck by how well it worked. For £50 more than the the bike computer version of an Edge I had the deal on Amazon seems good. Plus with the 1:50k mapping for £25 my previous reluctance because you had to add yet more cash to use decent maps disappeared.
I'm also a bit of an impulse buyer
Re: GPS Again
Can you connect either Garmin to an external charger, eg dynamo hub, or are they both AA batteries only?
Re: GPS Again
They both run on AA but I think there may be a way of charging (rechargable) batteries in situ ... I could be very wrong though. Another option would be to use a AA charger powered by a dynamo.Can you connect either Garmin to an external charger, eg dynamo hub, or are they both AA batteries only?
Rocklobsrercat does this help ? Dakota screen earlier this morning
- rocklobstercat
Re: GPS Again
Yeah thanks for that. I think I'm going to go for the Dakota over the Etrex.
Re: GPS Again
Re the power options... I hadn't tried it before but I've just managed to get my Dakota 20 running direct off the Power Monkey unit (i.e. no AA's installed). That being the case, it should also work off a dynamo power feed :) The one "flaw" I've found so far is that the screen doesn't go into Power Saver mode and is constantly backlit.
